Help identifying these parts
Discussion in 'Mack Forum' started by Fredy, Jan 25, 2019.
  1. Fredy
    Fredy Light Load Member
    78
    12
    Feb 11, 2016
    Washington, D.C
    Hey tombstone69,
    It's not in between the two tanks.
    It seems to go from main primary tank towards the dryer (I think).
    It's weird because it's constantly leaking air even though air brake test passes.
  2. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,320
    Dec 20, 2018
    Jersey shore
    Maybe it's in the wrong spot.I thought the plumbing looked kind of weird.Was the original part leaking?
  3. Tombstone69
    1,010
    1,320
    Dec 20, 2018
    Jersey shore
    Take a picture of the dryer assembly and the line where it comes out of the tank.
  4. Tombstone69
    1,010
    1,320
    Dec 20, 2018
    Jersey shore
    The air dryer acts as a go between the primary and secondary before the air goes into service.In other words each tank should have a line going to the air dryer,the primary is the one with the protection valve. On the other side of the air dryer are the service lines.Is the dryer leaking constantly?
  5. Tombstone69
    1,010
    1,320
    Dec 20, 2018
    Jersey shore
    Well, at least you have a good compressor.What kind of truck is it?
  6. Tombstone69
    1,010
    1,320
    Dec 20, 2018
    Jersey shore
    A Granite.Is it a tractor or a dump.
  7. Fredy
    78
    12
    Feb 11, 2016
    Washington, D.C
    The dryer is not leaking; just this valve that I took a picture of. Both the new and old part have that "weep" hole but I have not switched them out yet since its been very cold outside. Its a roll-off truck btw. Thanks for your input!
    Edit: I will get a picture soon!
    Tombstone69 Thanks this.
  • Draft saved Draft deleted
