Help! Low air Buzzard?
Discussion in 'Trucking Industry Regulations' started by JJKid, Jun 7, 2015.
  1. JJKid
    JJKid Medium Load Member
    690
    513
    Aug 17, 2014
    Chicago, IL
    Lol, not sure i'm following here.
    I realize I made a typo; buzzard supposed to be buzzer!
    Other then that.. serious thread, atleast on my end.
  3. 201
    201 Road Train Member
    12,791
    26,318
    Apr 16, 2014
    high plains colorado
    Hi JJ, HA. I was going to say, look out for those "low air buzzards", as I hit a freakin' turkey ( about the size of a buzzard) with my 4 wheeler once, shattered the windshield.
    ANYWAY, unless they changed something, I was told, preferably both, but 1 or the other should be enough to pass. I'm confused what would cost so much. All it is, is a pressure switch, in line with your gauge, with a 12v buzzer, usually under the dash( so you can hear it) and when the pressure drops, it sets off the buzzer. At least that's how it was with the old iron. Who knows now?:dontknow:
  4. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    Ah, I probably jumped to an erroneous conclusion here, but come on man, you said two DOT cops were talking and you heard
    Now I know that it would seem like some drivers, even truck drivers are BLIND but I find it hilarious that a DOT cop would say something like that, unless it was in jest. . .:D
    Vilhiem Thanks this.
  5. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,002
    Jan 9, 2012
    glasgow ky
    You should keep an eye on all gauges to make sure everything is ok if you do this you will know what is going on. If all else fails you will know your air is to low when the brakes lock up.
  6. 6daysontheroad
    6daysontheroad Medium Load Member
    462
    698
    Dec 15, 2012
    North of the Rio Grande
    Probably would depend on year of truck. I would imagine technically it should be compliant with the date of manufacture. Some of the trucks I used to drive when I first started had no buzzer or light, just a mechanical flag that would drop down in front of you if air pressure was low.
  7. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    The OOS criteria reads as follows:
    Low Air Pressure Warning Device
    Low air pressure warning device missing, inoperative, or does not operate continuously if either the primary or secondary reservoir is 55 psi (379 kPa) and below, or 1/2 of the governor cut-out pressure, whichever is less. (393.51(c))
    NOTE: If either an audible or visual warning device is working as required,
    vehicle should not be declared out-of-service.
    BoxCarKidd and JJKid Thank this.
  8. JJKid
    690
    513
    Aug 17, 2014
    Chicago, IL
    Thank you Scalemaster.
    Would it constitute a warning or it should fufill the requirements and no warning/OOS will be given upon that particular violation.
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Federal laws are some times left to the states to interpret and enforce, they do not always do that the same. I thought the low air alarm (audible) was required to come on by 65 PSI. Thanks for the reeducation! A company I previously worked for had a truck put out of service in (?) a mid or north Atlantic state. The light worked but the alarm did not and had to be repaired or towed. Had a driver in training from S.C. , the company sent him with a trainer to S.C. to take his test in a Volvo White Heavy Truck Corp. truck the alarm would not work with the key on engine off but the light did. The buzzer came on the same as the light if the engine was running. All the other trucks were the same. Installed a old buzzard box like old blue to the left has and it passed. If the only thing wrong with your circuit board assy. is the alarm anybody that knows anything can install a buzzer pretty cheaply. Some times it's not worth the fight even if your are right.
  10. HeWhoMustNotBeNamed
    HeWhoMustNotBeNamed Crusty Pogosticker!!
    3,454
    19,721
    Jan 25, 2012
    Cartoon Network
    when a low air buzzard needs to go to higher altitudes they buy a ticket .... [​IMG]
  11. rambler
    rambler Road Train Member
    1,358
    582
    Nov 5, 2007
    Boy 6days, what you said brings back memories. I cut my teeth on a 1957 H model Mack. It also had a mechanical arm that dropped down in front of you for low air pressure. When pressure was built up sufficiently you could push the arm back up and it would stay up.
    Lol........buzzard the guy says.
    201 and 6daysontheroad Thank this.
