Help me interpret apu reading
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TheMeatMan, May 25, 2026 at 11:19 PM.
  1. TheMeatMan
    TheMeatMan Bobtail Member
    5
    So my Tripac evolution has been having issues lately. I’ve been waking up with it completely shut off with the red triangle and ‘eng’ light on.
    Sometimes when I start it it will blow cold for a minute but then the little frost icon will start to flash and stop blowing cold. The engine will stay on and the fan will blow but the a/c won’t kick in.
    I was able to get a reading of what’s going on when this happens and apparently the high pressure switch is kicking on and not letting it cool. I’ll post a picture of the reading as well as all the codes. The condenser is clean, condenser fan blows like it should and I wiggled the hpco switch and it didn’t cause a shutdown.
    As you can see the temp, rpm and coil temp are all high and the high pressure thing is open.
  3. TheMeatMan
    5
    There were no codes during this. The engine was running but it wasn’t cooling. Here are the previous codes.
