help me
Discussion in 'Con-Way' started by aman, Dec 17, 2010.
  1. aman
    aman Bobtail Member
    9
    laredo, texas
    how hard is the con-way 45 degree backing test in orientation i never did one in my school can u please explain to me how hard is it for a new driver that has never done a 45 degree backing the only thing i did in school was a straight line backing and parallel backing. i need help i dont want to get kick out of orientation for the backing test.:biggrin_2552:
    Trucking Jobs in 30 seconds
  3. slodsm
    slodsm Light Load Member
    255
    100
    Jan 19, 2008
    Tyler TX
    Little late and don't know where you went to school but I'm sure they did 90 degree backing tests there and if you passed that the 45 will be cake.
    Been years since I did Conway orientation but most of my class I also went to Central Tech with and they for the most part sucked backing anything up other than 2 of them and they all passed the 45 degree without a hitch. It's not bad at all.
  4. aman
    aman Bobtail Member
    9
    laredo, texas
    thanks for the help you realy help now i fill like i can do it
  5. Armycain
    Armycain Bobtail Member
    Jan 2, 2011
    Are you talking about an angle dock? It's mix of alley dock and straight dock but just take your time and line yourself up and you'll be fine
  6. Boomer08
    Boomer08 Light Load Member
    239
    40
    May 26, 2010
    I thought it was a piece of cake. You just have to remember when to get out and look. They want you to get out three times at three specific points while backing. You will do fine.
  7. aman
    aman Bobtail Member
    9
    laredo, texas
    thank you all for your help the way you putit i fill i will do fine thank you so much guys
  8. Boomer08
    239
    40
    May 26, 2010
    One suggestion that helps, at least I think is to let someone else go first and then you can see exactly what you need to do and when to do it.
  9. aman
    aman Bobtail Member
    9
    laredo, texas
    yes thats true thats what im going to do thanks
  • Draft saved Draft deleted
