Help needed resetting codes on 2016 Freightliner Cascdia DD15
Discussion in 'Freightliner Forum' started by rollingon46, Dec 27, 2021.
  1. rollingon46
    rollingon46 Bobtail Member
    9
    Dec 22, 2021
    Changed Inlet and Outlet Knox sensors and now more codes are coming up. Can someone help me clear them?
  3. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,605
    Jun 3, 2018
    Can you do a parked regen?
  4. rollingon46
    9
    Dec 22, 2021
    I did a parked regen and it gave me another inlet code and SPN 3223 FMI 7 and SPN 3270
  5. rollingon46
    9
    Dec 22, 2021
    I know what the codes mean but nothing else is really wrong with it.
  6. LoneRanger
    3,695
    9,605
    Jun 3, 2018
    can’t be so sure. Without it being hooked up to diagnostic link while doing a parked regen you won’t know for sure if everything is working.
    I would suggest in looking into a cheap diagnostics tool that helps you at least to clear your codes and see if they pop up again.
    If I’m not mistaken and I could be wrong, I believe someone once told me after replacing the nox sensor something much be changed in the ecm.
    can’t be sure but you need it diagnosed or cleared before you can see if it persists.
  7. WarnerS
    WarnerS Bobtail Member
    Dec 27, 2021
    Just bought OTR Proformance Software/APP after buying a 2011 Peterbilt 386. Good buy on both Peterbilt and OTR from my point of view today. Yes you do have to tell the ECM what you did, so far I have not been to Peterbilt hanging on a wrecker.
  8. rollingon46
    9
    Dec 22, 2021
    I guess I am going to have to purchase another diagnostic tool.
  9. Antinomian
    Antinomian Road Train Member
    2,171
    3,441
    Feb 17, 2013
    rollingon46 Thanks this.
  10. rollingon46
    9
    Dec 22, 2021
  11. WarnerS
    Dec 27, 2021
    Take a look at the you tube and other video's before you buy. I had a quote for a service truck for around 4 hundred just to look at my codes. The truck had already de rated.
    Wrecker was a min of 400 to the closest Peterbilt Shop. I have a farm shop where the truck was sitting. Two hundred for OTR hardware and $50.00 a month after first year - buy in package was 800 on sale. 1st. Found dosser valve completely junked. Paid Cummings Parts 605.00-Peterbilt was 670.00. Replaced doeser, cleaned everything from firewall to muffler. Spent several day under truck and use the diagnostic tool may time -look for active alarms. All alarms cleared and I have been using the truck for its intended purpose. Truck not 100% "yet" is throwing a high temp exhaust alarm 990 degrees but resets with the OTR. With the OTR I can also look at live data and do resets. Peterbilt codes suck -Have not found a good conversion table. So my work has been look, clean, replace if visually bad-Test with OTR/reset. Look for conversion code-OTR has some in the software.
    The truck has 355,000 miles (we just bought it after a cumming engine blew on another truck) so I am doing full service on the Peterbilt. Almost complete and have spent many dollars less the the bill would be in the big shop.
