Help! No trailer lights work
Discussion in 'Freightliner Forum' started by Firedawg11, Feb 13, 2016.
  1. Firedawg11
    Firedawg11 Bobtail Member
    32
    9
    Feb 13, 2016
    I was tboned 2 weeks after getting my truck on thanksgiving night when a guy crossed center line on single lane highway was gonna be head on but I swerved and he ran down my side and into drives might have loosened wire on impact
  3. Firedawg11
    32
    9
    Feb 13, 2016
    Holy ####!!! Kick plate ground!!! So loose that I wiggled it and bam working! Thank you so much guys.., back to making $$$$
  4. tech10171968
    tech10171968 Medium Load Member
    627
    851
    Nov 16, 2009
    Daytona Beach, FL
    You're welcome. Kind of helps that I drive a 2012 Cascadia, too, LOL!
    Starboyjim, jammer910Z and Mudguppy Thank this.
  5. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    Without ground... 1 million volts won't spark an 1157.
    Also, if you've ever sprayed a water hose in you're cab floor to rinse out the vinyl flooring, you easily could have corrosion in that panel or somewhere in that firewall.
  6. jammer910Z
    2,446
    6,525
    May 28, 2015
    Good. Always check ground FIRST w electrical issues.
    Glad u got it.
    j_martell and ‘Olhand Thank this.
  7. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    TA mechanic? That doesn't sound encouraging. The electric cord has 2 ends, you know that, have you spread the pins with a small screwdriver or knife? Also, the wires are bolted into the plug with screw tensioners, you can check those. If you're getting intermittent functionality, it sounds like a fairly straightforward (inexpensive and easy to repair) problem. Best.
  8. Dave_in_AZ
    430,072
    There is a fuse box under your hood / driver side / near the fire wall. Check trailer lights fuse.
  9. Firedawg11
    32
    9
    Feb 13, 2016
    I checked every single fuse on truck, turned out I needed to remove kick plate and the ground by clutch was loose, added 2 washers to it and make it snug and back in business!!!
  10. cedarstix
    cedarstix Bobtail Member
    What ended up being the problem? We have 2 2013 Cascadia day cabs with the same problem
  11. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    ....did you not read the thread?
