help please advise
Discussion in 'Freightliner Forum' started by plowboy turned trucker, May 25, 2019.
  1. plowboy turned trucker
    plowboy turned trucker Bobtail Member
    May 25, 2019
    2013 Freightliner Coronado mirror brackets tight but keep folding towards the doors while driving. How can I fix?
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Dont know their design. If you can remove bolt(s) and separate the two moving surfaces. Slide a serrated washer in and tighten it back up. Those type of washers have "teeth" and they grip quite well. May get stainless serrated if possible.
    plowboy turned trucker Thanks this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Are you talking the tube brackets with clamps on them? If it's moving it's not tight. Maybe replace the bolts on the clamps.
    If that doesn't help, I would just get some small stainless steel bolts (like #6) with lock nut. Drill a hole through the tube at the location you want and drop the bolt in to use it like a stop.
  5. plowboy turned trucker
    May 25, 2019
    Tube type but no clamp. Just has a bolt at the top.
    stillwurkin Thanks this.
  6. 2hot2handle
    2hot2handle Light Load Member
    67
    34
    Aug 25, 2015
    It also has three bolts behind the cover on your door. Cover held on by one t25 torx bolt. Remove cover and inspect. Those bolts are t30. Tighten up good and wrench on the pivot point up top too. If still loose replace Hardware like the previous guys said.
