HELP question about vehicle passing DOT inspection.
Discussion in 'Ask An Owner Operator' started by Taylor506, Jan 2, 2021.
  1. Taylor506
    Taylor506 Bobtail Member
    Jan 2, 2021
    Connecticut
    I drive an expedite van. I do know there is a site just for that but I posted there like 2 days ago and have yet to get a reply. I just need to know, will a vehicle pass DOT if there is no audio cue for ANY of the dash lights. (No clicking for turn signal, no chiming when you leave your keys in) BUT it all still works like it should minus the audio. Do you think the van will pass inspection?? Thabk you expressly for your replies.
    (And yes, I understand that these will mostly be people's opinions and personal experience)
  3. Lonesome
    Lonesome Mr. Sarcasm
    11,707
    24,414
    Dec 15, 2007
    Northern Indiana
    I've never had a DOT inspection where they get that detailed. YMMV
    BUMBACLADWAR Thanks this.
  4. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    not that i am aware of. only if each light does not work, will be the problem,
    as for not getting any answers, the past couple of days, you do realize it's the holiday season, and many are on vacation, from not only work, but from the computers as well....????
  5. Ridgeline
    22,724
    123,366
    Yes,
  6. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    Yep!
    Accidental Trucker Thanks this.
  7. AKDoug
    AKDoug Medium Load Member
    323
    802
    Mar 21, 2018
    My new Kenworth turn signals make no noise at all. I'm not even sure if visible lights on the dash are a requirement. They really only care if the exterior lights work. Any other noises in the cab, keys in the ignition, lights left on, etc.. are not an issue with commercial vehicle inspectors.
  8. TallJoe
    TallJoe Road Train Member
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    If we talk an expediate van, it must be something like Sprinter so it should not matter but for a semi truck you won't pass the inspection for the air brakes, if your buzzer don't work when the PSI gets below 60 PSI.
  9. dibstr
    1,308
    932
    Sep 10, 2010
    Actually either an audible OR visual signal is required, Also it’s 55 psi both for a violation and OOS, not 60.
  10. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    I've driven trucks that the "maracas ' from the turn signals ,flashers and more..could be turned off on the dash menu , so wouldn't seem to matter.If you're talking about a scale house inspection? I've always been sitting in the seat actuation the controls, while they're 15 feet in front of me.
    Lonesome Thanks this.
  11. TallJoe
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    Then I'll stay corrected, if you say so...
