HELP SCANIA P360 ECU SHUTDOWN
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sanaaamar, Nov 30, 2019.
  1. sanaaamar
    sanaaamar Bobtail Member
    15
    4
    Feb 27, 2018
    Hello Truckers
    My Scania P360 has shut down with ECU error. Please take a look at the uploaded pictures and videos and let me know what to do. The urgency is killing me.
    Any one has experinced this? Any one who can fix this?
    Thanks
  3. sanaaamar
    15
    4
    Feb 27, 2018
    starter isn't working as well
  4. Oxbow
    Oxbow Road Train Member
    13,680
    141,878
    Nov 24, 2015
    daf105paccar Thanks this.
  5. KVB
    KVB Heavy Load Member
    877
    2,875
    Jun 30, 2012
    Hard to read the faultcodes in the video, but it looks like every system has faults, which makes me think it is a power supply or ground problem. Or main CAN-bus.
    These are common to all the main systems.
    First thing I would do is check battery connections and main ground, from frame to battery negative (on battery and on truck frame).
    Specially ground. Too often overlooked and ignored, and it is the most important connection in the whole truck, even more than positive power. Bad ground causes all kinds of crazy problems.
    Could also be main CAN-bus which transmits data between all the systems, like engine, ABS, transmission, V-ECU, dash, etc.
    But my first guess would be ground or 24Volt power connections.
    I know, a bit late, and probably not much help, but maybe it points you in the right direction.
    Whereabouts are you? If in my area, I could come with diagnostic computer, but I fear you are in completely different part of the world.
    Good luck. Hopefully problem is fixed already.
  6. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Looks like previous generation .
    They have a known issue that 2 computers go dead without warning.(not in all but if yours is one offf them....................)
    sanaaamar and Oxbow Thank this.
  7. sanaaamar
    15
    4
    Feb 27, 2018
    I connected the computer to my P420 model chassis and it shows exact same errors.
    Oxbow and daf105paccar Thank this.
  8. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    I am not a Scania expert but looks like you have 2 dead modules.
    Oxbow Thanks this.
  9. sanaaamar
    15
    4
    Feb 27, 2018
    P420 is running just fine with its own ECU, however when I connect this problem ECU to the P420 it shows exact same errors. I am too afraid of connecting the no problem, currently running P420 ECU to my P360 model.
    daf105paccar and Oxbow Thank this.
  10. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    I think it is time to ask Scania which is the best path to follow.
    Oxbow, spsauerland and KVB Thank this.
