Help! Trailer sitting on locking pins
Discussion in 'Questions From New Drivers' started by SABTLLC, Jun 12, 2018.
  1. SABTLLC
    SABTLLC Bobtail Member
    Nov 30, 2017
    Does any one know how to get the doggone trailer back on the frigging locking pins??? Our driver just sent us two pictures and the dang trailer is sitting ABOVE the doggone locking pins. How in the heck am I supposed to tell him how to have that fixed while on the road...
  3. mr truckdriver
    mr truckdriver Light Load Member
    286
    178
    Mar 2, 2008
    ft myers fl
    Is it loaded or empty. Either way need to pick up the trailer from the back to take the weight off the pins so they will retract.
    Bean Jr. Thanks this.
  4. razor1983
    razor1983 Medium Load Member
    500
    509
    Jan 17, 2011
    What the hell? How did he manage to do that?
  5. Chinatown
    Chinatown Road Train Member
    77,951
    185,436
    Aug 28, 2011
    Henderson, NV & Orient
    Did he try a sledge hammer?
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If its loaded you must jack up trailer or call a tow truck and beat the pins in, or if empty get a big hammer to beat pins in till it drops down
  7. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    If trailer is empty slide carefully tandems all the way back. Carefully!!!!! Not to slide the tandems out of under trailer.
    Forklift or two jacks under DOT bumper to lift trailer tail and retract pins.
  8. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
  9. plankton
    plankton Medium Load Member
    457
    631
    Jan 9, 2015
    He some kinda sissy or something? Tell him to pull that handle like he's got a pair!
    Brickwall, ChaoSS and buddyd157 Thank this.
  10. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Maybe a sledgehammer and somebody holding a piece of steel or pipe. These wil have to be beaten back inside. Just make sure to use something that's bigger than the hole so it doesn't end up being bound inside after the trailer pin pushes through.
    You're not going to be able to use the springs and linkage and handle to "pull them" into the retracted position
    Bean Jr. and 06driver Thank this.
