Help...trouble shifting into 6th gear.
Discussion in 'Questions From New Drivers' started by Sheriff1/6, Jan 7, 2013.
  1. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,909
    54,722
    Dec 8, 2012
    hunting...../ retired
    Did that once myself on a old CL9000 Ford that had an over-drive...Thats 9th and 10th were reversed for you folks from Rio Linda.......
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    LOL-cl ford 1st airride cab I ever drove that tall #### cabover scared the bejeezus outta me for the 1st month or so--
    Tonythetruckerdude Thanks this.
  4. Tonythetruckerdude
    2,909
    54,722
    Dec 8, 2012
    No kidding man...the 1st time I started into a curve with that thing I thought ....well I'm fixing to know how it feels to roll over....It sure took some getting used to.
  5. sleeve62
    sleeve62 Light Load Member
    75
    55
    Apr 8, 2012
    Rittman, Ohio
    My Freightliner had another interesting trait , in addition to the shift pattern. The previous owner had turned the " pump " up considerably. When you attempted to drive under load in OD , it didn't take long for the engine to overheat. Reminded me of Scotty on Star Trek and his " laws of physics " spiel ! Not enough radiator. A horsepower is 33,000 ft. lbs./minute , or 2545 btu. per horsepower hour , 3413 btu. per KWh. Immutable , as they say ! I had to get A bigger radiator, 6 coils deep. (Burn more fuel , dissipate more heat !) I turned the pump down some also, All OK....... Lessons learned as A kid messing with cars . Putting A 750 CFM Holley double pumper on my Chevy 327 , without changing anything else, did not create A " hot rod " ! It created A mess, an expensive one that wouldn't even idle , let alone compete at the drags ! It all worked in my favor though. The guy thought the truck was FUBAR and I got it for $800.00...........
  6. BossOutlaw88
    BossOutlaw88 Road Train Member
    1,451
    352
    Oct 30, 2011
    Cali
    Don't worry, that actually happened to me after leaving Werner for Schneider. Werner drives 9-speed top 2 trannys while Schneider has 10-speed. You should have seen the test out rider's eyes when I kept skipping 6th gear lol!
    Sent from waterproof phone using Tapatalk 2 Blue
  7. sleeve62
    75
    55
    Apr 8, 2012
    Rittman, Ohio
    Today the components in most trucks are pretty much standard , really not too difficult to figure out due to the limited variables. Some years ago I worked for A dry bulk hauler who had all Mack day cabs . Fleet upgrades created A mix of B and R models with A wide array of driveline components......Mack Triplex , Quadraplex , big box 20 speed , OD, small box 18 speed , 9 speed overdrive , and A few Duplex , leading into the straight 5 speed Maxitorque coupled with the 300+ Engines. 1 Diamond T , 290 Cummins , 10 speed Road Ranger going through A 2 speed Brownie , which was not user friendly shifting while in motion......There was also A Mack version of Road Ranger and on into Mack 12 speeds ( sorta' triplex with air shifted auxilliary) , very nice to drive , I think , and also A kinda' clone of the Spicer SST , air shift, that seemed to be A " junky " version of the 2 stick , 6x4 Spicer which caused far fewer problems.....Took me some years to overcome my distrust of " air + transmission combinations ". Had A Mack with A PTO , 10 speed air shift with no stick position for reverse, only an air shuttle that could render you " forward only " if it hung up in sub-zero weather.....Today , all pretty much the same , and not nearly as entertaining. And then the women driving to work in the morning stopped wearing mini-skirts .......
  8. killer120
    killer120 Light Load Member
    70
    43
    Jul 1, 2013
    i use a 9 speed also, so pretend this is a 10 speed, i start in 1st then go to second, then third, then flip into high and go into 6th. i do this because the momentum has pushed me enough to go into 6th and still be at 1400 rpms. i shift at 2000 rpms, try this it may work for you (i haul at 92k pounds by the way)
  9. Brookshire36
    Brookshire36 Bobtail Member
    18
    Apr 28, 2020
  10. Brookshire36
    18
    Apr 28, 2020
    I think you just answered my question I be looking for an answer, my truck is a 9 speed supposed to be, but if I go from 4th flip high go to 5th just like a normal 8speed, but I can also go from 4th gear flip to high go back down to low and shift like I guess 9speed, if I goto 4th on low, flip switch I can't go into the gear in low spot on high side, does this make sense to you
  11. Moosetek13
    Moosetek13 Road Train Member
    14,994
    19,060
    Nov 1, 2010
    Burnsville, MN
    Not anymore.
    I've been in auto's for many years, and you just revived a 9 year old (almost to the day) death thread.
