HELP Truck doesn’t start unless I spray ether
Discussion in 'Ask An Owner Operator' started by Anarchy2021, Sep 2, 2023.
  1. Anarchy2021
    Anarchy2021 Bobtail Member
    17
    Oct 27, 2021
    I have a 2005 freightliner Columbia it doesn’t start without spraying ether. New injectors fuel pump & took it to the mechanic they can’t figure out the problem. HELP!
  3. Arctic_fox
    4,510
    25,491
    Sep 16, 2016
    You checked the batterys? Could be they are right on the edge of being able to start the truck due to being so worn out. Obvious i know, but eaiser to rule out the obvious before you open the can of worms no?
  4. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    Check your fuse box for corroded fuses. It’s possible the one for the ecm isn’t supplying the necessary voltage to make fuel system to operate correctly.
    If it runs fine once you get it started on ether this is more than likely your problem.
    It’s either that or a bad check valve allowing fuel to back flow to the tanks.
  5. Big Road Skateboard
    7,099
    40,296
    May 2, 2021
  6. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    How long will it stay running? How long ago was the injectors done?
  7. Gio1980
    Gio1980 Bobtail Member
    11
    6
    Sep 3, 2023
    Check the voltage to the electric fuel pump/the transfer pump. Especially if you just changed the oil and fuel filters recently.
  8. Ridgeline
    22,724
    123,397
    omg, stop using ether.
    find another mechanic who is competent and let them figure it out.
    If it is a Cummins bring it to a Cummins shop, an actual one not one with a "certified mechanic".
  9. abyliks
    abyliks Road Train Member
    4,123
    9,716
    May 2, 2010
    ludlow MA
    Ether is like meth for trucks, one wiff and it seems like you are using it till the day it dies
  10. marmonman
    marmonman Road Train Member
    1,417
    2,843
    Dec 14, 2009
    central illinois
    Well, a little more information is needed.
    My truck won't start without ether is not a whole lot to go on to put you in the right direction to fix the problem.
    Something like it cranks and cranks but won't start in the morning or it won't start even after running as soon as you shut it off.
    Maybe even it started right up until I had the injectors and fuel pump replaced.
    What made you decide to replace said parts to start with?
    Was it doing this to start with?
    Information is the most important part of any diagnostics before starting to throw parts at anything.
  11. Tropsnart
    Tropsnart Road Train Member
    1,130
    2,386
    Jun 8, 2015
    Pavilion New York
    Seems like it may be getting air in the system. Filter o ring or fuel line not tight enough maybe.
