HELP! Water Pump for DD15 engine replacement options needed
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sroemer3948, Jul 8, 2021.
  1. Varga
    Varga Bobtail Member
    40
    38
    Sep 20, 2018
    You can fit the older style water pump but need to disable the variable speed water pump feedback with the dddl software. Also need the pulley and the belt from the regular water pump system. Simple we done many times
    Oleg D, spsauerland and Magoo1968 Thank this.
  2. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    Can you provide any screen shots from ddl on this?
  3. Varga
    40
    38
    Sep 20, 2018
    Hammer166, Oleg D, joeynapp and 3 others Thank this.
  4. Varga
    40
    38
    Sep 20, 2018
    Don't forget use the pulley from the old style water pump and the belt from the old style pump. The original belt is too long.
    Oleg D and spsauerland Thank this.
  5. RubyEagle
    RubyEagle Medium Load Member
    632
    790
    Apr 17, 2010
    Jeez hope you get it figured out man!
  6. 74alanlane
    74alanlane Bobtail Member
    I have a 14 cascadia I have replaced water pump and pulley but can't find the parameters for the variable speed water pump, only code that is showing is low coolant level. Do u know if it would be listed different. I have found it on newer trucks.
  7. CascadiaMike561
    CascadiaMike561 Bobtail Member
    Low coolant level might be the sensor that sits on the Coolant resvior..... Check your fluids it should be above that sensor. Those sensor do go bad often
  8. Varga
    40
    38
    Sep 20, 2018
    You have to go through MCM settings each by each. Sometimes when you do not have the legit triple D have glitch in the software. I was checked on the 2013 yesterday. Same parameter under same location.
  9. RippleTransport
    RippleTransport Bobtail Member
    Could you give me an idea where I can buy the software you use?
  10. Oscar the KW
    12,247
    28,119
    May 19, 2011
