Help !!! White smoke : Raw fuel
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rmj1980s, Jun 19, 2019.
  1. Rmj1980s
    Rmj1980s Bobtail Member
    7
    4
    May 7, 2019
    Hey guys I really need help on this. I have a 2012 kw 660 isx fresh rebuild. Done about 12,000 miles on it. Since the first run my truck blows white smoke which is fuel it happens when I press the pedal or going uphill as soon as I let it go it stops. If I’m cruising normal it won’t do it. I’ve already changed a injector, swapped a turbo, all the fuel lines, fuel pump , fuel rail and some sensors that pertain to the fuel system (3) I know it’s not a regen issue. When I bought it had some work done to it. Was told oil cooler is leaking going to change it when I get back . Any help, ideas or feed back is appreciated.
    marmonman Thanks this.
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Who rebuilt the engine?
    Dino soar, spsauerland and AModelCat Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    More questions than answers........
    How is it that you can see any color smoke from the exhaust?
    Why do you think that an engine oil cooler will fix a smoking condition?
    How is it that you " know" it is not a regeneration issue?
    Any oil or coolant consumption since rebuild? oil sample?
    What tests have you done to the fuel system other than change parts........rail decay, IPT test, injector return flow rates?
    Dino soar, Proxy, Heavyd and 4 others Thank this.
  5. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Raw fuel? Sounds more like raw coolant with all that white smoke.
  6. Proxy
    Proxy Light Load Member
    165
    54
    Sep 3, 2018
    As Goodysnap said, definitely more questions than answers.
    I agree with Cam Roberts, without knowing more this is very likely
    Goodysnap and Cam Roberts Thank this.
  7. Rideandrepair
    17,560
    56,893
    Aug 8, 2015
    Isn’t Cummins famous for egr cooler leaks? Coolant leaks into exhaust and soaks sensors.
  8. Navtech
    Navtech Light Load Member
    62
    43
    May 9, 2019
    White smoke with fuel smell is areated fuel, most likely a fuel injector I would get it checked out ASAP because it can burn a hole in a piston.
    Rideandrepair Thanks this.
  9. Cam Roberts
    1,621
    1,938
    May 13, 2018
    This a cummins diesel. not a ford stroker. I sense the confusion judging by your avatar.
    Not gonna happen and not the case
  10. Navtech
    62
    43
    May 9, 2019
    I’ve seen it on an ISL multiple times. Although having aftertreatment could be related to AFI. (Also powerstokes and all international v8 engines are garbage in my book)
  11. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    By his original post, I think his aftertreatment may have fallen off.
    Oxbow, Rideandrepair and Goodysnap Thank this.
