Help with 9 speed transmission
Discussion in 'Questions From New Drivers' started by Evie3, May 15, 2017.
  1. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    NO you don't need to be at the right mph to downshift. That's what everyone is saying. You need to be at the right rpm to downshift. Shifting a truck is more about listening to the engine, and paying attention to the Tach, not the speedo.
    207nomad and Vic Firth Thank this.
  3. AModelCat
    165,065
    Exactly. Shifting into 3rd at 15 mph in one truck might be fine but jump into a different truck and you might be wound out at 2200 RPM at that same speed. Speed is and will always be a variable between trucks. RPM range for shifts will always be pretty much the same in any truck you'll ever encounter.
    Tb0n3 Thanks this.
  4. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    There is a "low high". I use it when I'm climbing heavy.
    sealevel Thanks this.
  5. Ridgeline
    22,752
    124,078
    DO NOT listen to the engine, read the tachometer, that's there for a reason.
  6. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Roughly speaking
    If his rpm tachometer is 1,000-1,100 rpm, he can downshift 1 hole. If 1,000 or less rpm, he can skip a hole and downshift 2 holes [if in the lower half of gears]. Modern engines can pull across a wide range (road speed and engine rpm) without being a problem. They won't let you over-rev, and going up hills, as long as you downshift at around 1100-1200 rpm, everything will be fine.
    When accelerating, shifting up 1 can be done most anywhere from 1200-1500 rpm, depending on load, grade and your mood. Slower road speeds will generally prefer lower rpm shift points.
    Memorizing and trying to sequentially shift up and down with speeds is more difficult (mentally and in practice) then it needs to be. Working with rpm (until you develop a natural "feel") is easier and works with any truck and any transmission and drive axle ratio combinations.
  7. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    This is not intended as a put-down of the person who's the subject of this post because there are many hundreds of new drivers on any given day struggling with shifting a manual truck transmission and who were poorly trained, and look for "cheat codes" thinking these will be the solution ... but this is a big part of the reason most carriers are moving to autos.
    Bean Jr. Thanks this.
  8. Yourawahoo
    Yourawahoo Light Load Member
    84
    28
    May 8, 2017
    Shifts like a 13 speed, but you can't split high side gears.
  9. Yourawahoo
    84
    28
    May 8, 2017
    A ten speed drops 5K with each shift and a thirteen speed drops 3K. 18 speed 3 also.
  10. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    What kind of truck are you driving where it drops 3-5000 rpms with a gear shift?
    Bean Jr., AModelCat and BigTennOTR Thank this.
  11. Yourawahoo
    84
    28
    May 8, 2017
    Well from 21 RPMS to 18. What would say that is eignstein.
