i am wondering if the stock coax is used for cb radio and tv in these trucks and can it be tuned or should i just get new coax and antenna mounts? also i am wondering if i should go with coiled antennas or good ole fire sticks with adjustable tips.
help with a 06/07 freightliner
Discussion in 'CB Radio Forum' started by bluechevyv, Jan 31, 2010.
The stock coax is junk. get some good rg8 or mini 8 coax to run for your cb. You only need one antenna. if your running a stock radio with no extra power get you a francis 5' fiberglass and it will be pre-tuned already to the cb freq's. That is a great setup for a stock radio. If you want to run a coil antenna get a predator 10K. if you need to know where to get one let me know and I can give you the info for Kale's ( AKA. cowtown kid - the builder ) distributor.
Where do I get me one of these predators?
Here is John's telephone # 817-454-3455. He is Kale's direct distributor. You can call him and let him know what your application will be and he'll recommend the correct model for your setup.Punisher1985 Thanks this.
cool ill get a hold of cowtown. he is local for me.
Thank ya sir! How much they run?
Depends on what model you get he makes several. Best I remember they start around $65 and then go up, but they are well worth the money. Just tell him what your running for a setup and he'll guide you to the right choice. Very good guy to work with and talk to.
