Help with a load
Discussion in 'Ask An Owner Operator' started by Roman78, Aug 9, 2022.
  1. Roman78
    Roman78 Light Load Member
    74
    27
    May 20, 2021
    I have a reefer unit as a loadout trailer. The broker told me I cannot turn on the reefer. now, I im stuck with no loud because no one accept a reefer or dry goose. Can I turn on the reefer?and take reefer load. Will they know and change me. ? Help
    pumpkinishere Thanks this.
  3. Chieftains
    Chieftains Medium Load Member
    362
    896
    Jul 18, 2021
    You can load most dry van loads on reefers. Change your selection on DAT to VR van or reefer
  4. pumpkinishere
    pumpkinishere Heavy Load Member
    945
    4,987
    Apr 21, 2021
    You would need to fuel the reefer up when done with it but there isn’t a way to my knowledge that they could tell if reefer is running or not. Is the reefer working? Did you haul a reefer load or just in a reefer trailer?
  5. Dave_in_AZ
    426,809
    Maybe something is wrong with the unit, or it needs serviced at a certain amount of hours.
    D.Tibbitt, Siinman and pumpkinishere Thank this.
  6. Jacoooooooo
    Jacoooooooo Heavy Load Member
    748
    1,054
    Oct 20, 2013
    They may have noted the unit hours - just a hint.
  7. Roman78
    74
    27
    May 20, 2021
    Yes its working i delivered a load with it to NC. I just find it stupid when broker add the line the reefer can not be used during load out. Only as a van.
  8. Siinman
    Siinman Road Train Member
    5,533
    14,226
    Mar 5, 2017
    Kansas City, MO.
    Some reefers have it hooked up to network. can see live data on it anytime anywhere.
  9. pumpkinishere
    945
    4,987
    Apr 21, 2021
    Then that is what needs to be done. You agreed to using it only as a van so keep looking you will find something.
  10. Dave_in_AZ
    426,809
    Or the guys knows how things can go quickly south, and the reefer load back gets turned into a week long fiasco and now has another 200 hours on the unit.
  11. pumpkinishere
    945
    4,987
    Apr 21, 2021
    The broker is paying you for the load. You want to be paid so you follow their agreement. You could call them and ask if you could use the reefer and if they say yes I would get it in writing. Otherwise I’d keep looking.
    Siinman Thanks this.
