Help with Battery.
Discussion in 'Ask An Owner Operator' started by Marco22, Sep 21, 2015.
  1. shovel98
    shovel98 Light Load Member
    251
    241
    Jan 15, 2011
    mn
    Usually the higher CCA shorter life of the battery. Plates are too close together. I go for anywhere from 750 to 850 CCA heat and vibration kill batteries fast just whats been working for me I usually see four or more years outa mine and yes I live in north central mn and don't have no starting problems.
    Dominick253, Terry270, Marco22 and 2 others Thank this.
  3. rollin coal
    rollin coal Road Train Member
    13,714
    28,241
    Mar 29, 2008
    TN
    If you have one bad battery always, always replace all 4. One weak battery will ruin 3 good ones. Had a buddy putting new batteries in every 6 months one at a time...
  4. 201
    201 Road Train Member
    12,857
    26,463
    Apr 16, 2014
    high plains colorado
    Hi Marco, I agree, if one is bad, that will ruin the others. ( and put a strain on the alternator) Vibration is the batteries worst enemy. The stuff on the plates falls off and collects on the bottom, and shorts out the cell. Batteries have come a long way, as well as smother rides, but years ago, it was not unusual to go through batteries once a year. If you never go where it's cold, (like below 0), 3 might be ok.
    Dominick253 and Marco22 Thank this.
  5. sshewins
    sshewins Road Train Member
    1,631
    4,730
    Aug 21, 2011
    Of course, I have a T600 and only has 3 batteries. I recently had to crimp on new ends on the cables. They were trashed. It's does really good now.
  6. Diesel Dave
    9,783
    33,812
    Jan 20, 2010
    Hesperia, Ca.
    Times 2........I usually get the same life also, DEKA Batteries is what I'm running now, American made and quality, going on my third year with them and still strong.
  7. Marco22
    Marco22 Bobtail Member
    6
    Sep 21, 2015
    Thanks everyone for all of the advice and tips. I really appreciate it.
    Dominick253 and sshewins Thank this.
  8. Derailed
    Derailed Road Train Member
    2,385
    2,657
    Dec 10, 2008
    Upstate NY
    Like the others said, definitely check your connections and cables for corrosion and clean them up. As far as batteries I've always had good luck with Interstate. I have 4 of the 31MHD in my Freightliner. 950 CCA. The 2 I recently pulled out of my f350 were 10 years old before they started failing.
    Dominick253 and mitmaks Thank this.
  9. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    you can buy a small spray can of corrosion protection. it sprays a red color & keeps corrosion off cable ends & battery connections. I use it on all electrical connections, alt, starter, wires e.t.c.
    Dominick253, rollin coal and sshewins Thank this.
  10. Diesel Dave
    9,783
    33,812
    Jan 20, 2010
    Hesperia, Ca.
    I'm bringing this thread back to life. DEKA BATTERIES ARE JUNK !!!!! I just had my experience with a set of 3 and only lasted 2 1/2 years, when with others had longer. Others that have used DEKA have been changing at 18 months to 2 years. I went back to Interstate, JCI makes them. I went with the MHD's , costs, $314.00 out the door for 3. A friend that works there hooked me up. That was he's discount.
  11. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    Man, you're complaining about 2 1/2 years? I'd love to get that long out of them. I switched up to deep cycles this time, and went from 3 to 4 batteries. Only time will tell.
