help with detroit 14 l 515
Discussion in 'Trucks [ Eighteen Wheelers ]' started by thunder64, Sep 25, 2011.
  1. thunder64
    thunder64 Bobtail Member
    angleton texas
    i have 2006 frieghtliner haveing trouble with it loosing coolent i have spent way to much money on it all ready i put egr cooler radator truck does not run hot ever thing runs normal but when in a hard pull it makes a noise like a air to air leak replaced air to air had trubo rebuilt v pod changed still doing it i dont know what else to do please help
  3. serjev
    serjev Bobtail Member
    6
    6
    Jan 11, 2011
    Miami, Fl
    Has you replaced the thermostats? It, happen to me too, it was leaking trought the reservoir but was hard to find since the leak was coming only while i was driving, detroit replace the thermostats and told me than the problem was that the gasket that goes around the thermostat was too old and not was sealing right, anyway it works for me.
  4. gerardo1961
    gerardo1961 Road Train Member
    1,757
    630
    Feb 21, 2010
    Miami
    Before when I ws co driver were have the same problem with coolant loosing,was changing radiator ,after egr unit,finally was the headcasket,the coolant was loosing via exhaust
  5. Izlomik Supatrucka
    Izlomik Supatrucka Light Load Member
    158
    20
    Oct 24, 2009
    Texas
    is this kerry by god hill?
    i thought you had the coolant loss problem fixed?
