Help With Detroit ECU
Discussion in 'Trucks [ Eighteen Wheelers ]' started by GioPanama, Oct 14, 2011.
  1. GioPanama
    GioPanama Bobtail Member
    I Have a freightliner classic 1995 with detroit 12.7, it had a DDC III ecu, the ecu died so I buy an used one, but it dosnt have a plaque or piece of paper that say if its a ddc III or IV. When i start the truck it runs fine,but on the first trip, it make and engine failure, but just for like 2 second and also pulls smoke, then it get normal and runs fine, but does it all the time.
    I conect my laptop and it say oil temp sensor and the turbo sensor, I delete it the turbo one, but the oil no because I have to change the sensor. I put a new turbo sensor and the problem continues and keep saying is the sensor.
    Now the questions: How can I now if the ecu is a DDIII or IV? I get the ECU serial number with the laptop that is VF601434, but i dont know where to look if it is III or IV.
    2- Does the turbo signal or sensor can cause that engine failure?
    Thanks!
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    man, you have DDDL on your laptop. when you hook it up ECM ID window pops up!
  4. Sparkz
    Sparkz Light Load Member
    76
    16
    Jul 10, 2011
    New Zealand
    Not sure, but I think VF ECM's are DDECIV.
    Are you using DDDL or some other diagnostic program?
    What software level does you program report the ECM as? DDECIII will be R9 or similar. DDECIV will be R20 or greater.
    Did you just fit the ECM, or did you get it reprogrammed to your engine number?
    Did you set the injector codes?
    Exactly what fault codes are you getting? Flash code, PID, SID, FMI etc.
    If you send me your engine serial number and the engine number that the new ECM is programmed to, I can check to see if they are compatible.
  5. snapon2
    snapon2 Bobtail Member
    42
    8
    Jan 13, 2011
    grande prairie alberta
    ddec 3 and 4 will run your engine but the boost sensors are different.so you will have a boost sensor code if you put a ddec 4 ecm on a ddec 3 . with a boost code you may not get any fuel as it stays in smoke control till it sees 5 psi boost.if you have dddl on your laptop look at engine configuration data in diagnostics drop down to see what your ecm is programmed to
  6. snapon2
    42
    8
    Jan 13, 2011
    also oil temp,code will cause shut down .try unplugging it as it will change the code to a sensor fault and not shut it down, or change the shut down calibration to warning with your laptop
  7. pichu
    pichu Light Load Member
    103
    19
    Jan 18, 2009
    mexifornia
    dd3 and dd4 had different timing , you need chance the bull gear and camshaft to run dd4 ECM:biggrin_2554:
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    compare engine numbers in ECU and on engine.
  9. SAMMY D
    SAMMY D Bobtail Member
    I SWICH ENGINES ON MY 379 PETERBILT ,DETROIT 12.7 TO SAME ENGINE,THAT GOT FROM A FREIGHTLINER ,MINE BLEW,NOW THE ENGINE WILL NOT START,DDEC 3 ONLY RUNS 3 INJECTORS ,DDEC 4 WILL NOT COMMUNICATE WITH SYSTEM AT ALL,FIXING TO BUY ANOTHER ECM BUT DONT KNOW IF ITS GOING TO BE A MONEY PIT TRIYIN TO FIND THE PROBLEM
