Help with valuation?
Discussion in 'Flatbed Trucking Forum' started by rch10007, Jun 22, 2021.
  1. rch10007
    rch10007 Medium Load Member
    560
    860
    May 26, 2007
    Madison, AL
    Is there a way to look up a trailer VIN? I am looking at a 2018 Mac step with 3 axles…does anyone have experience with one of these trailers? I’ll attach a pic of the VIN plate. The owner says is a 45ton but the vin plate says 80,000?? Can you help interpret the vin plate?
  3. rch10007
    560
    860
    May 26, 2007
    Madison, AL
  4. rch10007
    560
    860
    May 26, 2007
    Madison, AL
  5. pavrom
    pavrom Road Train Member
    3,216
    7,408
    Apr 29, 2012
    NE illinois
    Calling the manufacturer will be the easiest
    rch10007 and Espressolane Thank this.
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    The VIN plate is frame rating of what it was made to hold, but the 3ed axle may have been added later so ck with Mac to see if they added 3ed axle and can give you a updated higher weight plate?
    rch10007 Thanks this.
  7. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    the vin is also stamped in the side frame up towards the noise. look on the left or right side
  8. rch10007
    560
    860
    May 26, 2007
    Madison, AL
    I put in a call...they have yet to respond...
    Are you saying the "80000" on the vin plate is what the trailer is rated for and then I should include axle ratings in addition to the 80000? So, if each axle was 20k, that would make this trailer capable of hauling 140k? That is the 80k plus 60k for the axles?
  9. beastr123
    beastr123 Road Train Member
    2,951
    24,205
    Jan 2, 2014
    Moose Jaw SK CAN
    80K should be the frame rating spanning a certain length of deck space and that should be the maximum load that the trailer can haul under permit.
    this is a brochure from Mac and you will find the ratings on page 3
    https://www.mactrailer.com/literature/Flatbed Brochure 1-8 2020.pdf
    rch10007 and MTN Boomer Thank this.
  10. cke
    cke Road Train Member
    6,173
    76,021
    Aug 4, 2013
    Colfax Wi
    2A35B4C5-AE76-4FCB-9163-A60A45DA5172.jpeg Moon lighting today. Oops wrong thread
  11. cke
    6,173
    76,021
    Aug 4, 2013
    Colfax Wi
    3D7DC4B7-AC38-42A2-8D86-45847BA91293.jpeg One stack Pete with a window behind the seat.
