help with weight
Discussion in 'Experienced Truckers' Advice' started by OOOYeah!!!, Aug 15, 2015.
  1. OOOYeah!!!
    OOOYeah!!! Bobtail Member
    22
    18
    Jan 10, 2013
    So my company put me in a 14 freight cascadia evolution and I haul reefer. No matter what I do with a full tank of fuel I weight 12700 on my steers even if gross is 60000 any advice or should I just stop filling up all the way my 5th wheel is all the way back
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    That's freightliner cascadias with a heavy detroit engine. Put your 5th wheel back in a sensible forward position. It's not going to hurt your steer weight that much more and it will help your fuel economy significantly by reducing the turbulence behind the tractor.
    The 12,700 can be lived with long term assuming you have a new tractor and appropriate steer tires and is not going to get you in a jackpot at the scales. Half of the fuel weight gets added to the drives so fill her up and don't worry about it. You have a Freightliner and this is your reality.
    OOOYeah!!! and snowwy Thank this.
  4. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    What's wrong with 12,700?
    If your tires and axle are rated for 13,000 you'll be just fine.
    I roll around with 12,600 on my steers. I have a longer wheel base so im trying to keep the trailer closer.
    ramblingman Thanks this.
  5. OOOYeah!!!
    22
    18
    Jan 10, 2013
    Im rated on my tires for 12350 and some states only let u run 12k or am i wrong dispatch says 12,500 so im a bit confused
  6. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Get better tires, and your axle should be rated for an appropriate weight.
    I guess check the states you go through, but there are a lot of trucks with heavy motors that are over 12 on the steers.
  7. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Today, half of the trucks on the road are in excess of 12,500 on the steers. You can thank CARB for most of that.
    Also, you can do some dieting and will help some and if you have a heavy co-driver, that's some additional weight to contend with.
    Upright Thanks this.
  8. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    DOT won't bother you if you're 12.500.I've ran that many times.If I weigh a load and its 500 over on any axle im going to go with it.
    Straight Stacks Thanks this.
  9. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    Don't worry about it. I've got a '15 Cascadia Evo and I can be as much as 13,600 on the steers. Never had a problem yet. I haul tanker and no matter what I do with the 5th wheel you can't get much change, despite being under gross. Scales seem to be more concerned about the weight on the drives. but like anything YMMV.
    Good luck.
  10. OOOYeah!!!
    22
    18
    Jan 10, 2013
    Its a co truck so better tires not much an option i will say this did finally get it to weight 12 at a cat scale rolled across Missouri and their figital screen said i was at 11 is there a chance ive had a bad pick of cat scales
  11. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    Better question. Do you set your brakes when you scale? If so, DON'T. It adds weight especially to the front of your truck.
    BigRedNY, finbyrd, truckon and 4 others Thank this.
