Help with Wheel Bearings setting
Discussion in 'Trucks [ Eighteen Wheelers ]' started by razor1983, Jun 28, 2016.
  1. X mech
    X mech Light Load Member
    64
    22
    Nov 14, 2015
    The second cause of bearing failure behind lack of lubricant is over tightening. Try that with your dial indicator and see that it's still in spec.
  3. X mech
    64
    22
    Nov 14, 2015
    Have you ever had cummins or Thermo King Factory reps come out and ask you how you repaired problems? Either you're a chef or you need a cookbook.
  4. jamespmack
    216,478
    I have. 4 gen owner op and past ase master truck tech. Was taught by the old guys. And learned a better way to do it. Problem is everyone is different. If its you and only you working on it fine. I could get it #### close. Had years of doing it that way. Would if its a emergency or sidebof road. But ive learned a better proven saffer way. Wont go back.
    tony97905 Thanks this.
  5. X mech
    64
    22
    Nov 14, 2015
    Of course they do, so does National and CR. Apparently it's not on the ASE test. Because I was the guy they called when the dealership screwed it up and had to weld on a new Spindle and rebuild it. All of their mechanics are ase-certified. Just an employer's tool to baffle the public. The joke was ask someone else is what it meant.
  6. jamespmack
    216,478
    Well it wasnt from doing it right.... problem is the under train and under pay mechanics. Nobody worth a c*** is will to do it. Ive done it most of my life. I know better. And i dont rush because its not worth it. Everyone says they dont make money as a truck tech. I did.
  7. Blackshack46
    Blackshack46 Road Train Member
    Have you ever lived in PA?
  8. jamespmack
    216,478
  9. Blackshack46
    10/4. I ask, because I was taught the trade by a heavy equipment mechanic named James Mack from PA.
  10. jamespmack
    216,478
    Really we are here all to learn not point fingers. Im still learning everyday. I allways took care of customers equipment like. It was mine. Forget the office guy telling you to work faster. Now i have my own truck I treat it like its a customers. So i dont get lazy.
