HELP!!!
Discussion in 'Freightliner Forum' started by Nando85, Jun 30, 2019.
  1. Nando85
    Nando85 Bobtail Member
    43
    6
    Aug 9, 2017
    I heard my turbo whistling check it found rubber elbow had a hole in it the one goes to air filter then it got worst check again found oil by the charge air cooler decided shut it down took it apart definitely found oil inside tube going towards cac so is my turbo gone?anyone had this problem?06 freightliner century 14 liter detroit 60 series
  3. JohnnyC
    JohnnyC Light Load Member
    173
    65
    Feb 17, 2009
    virginia beach, virginia
    Have it checked before you run it. My turbo blew on my truck and would have blown my engine if I didn’t shut it down. I own the same truck. After three turbos had it deleted. Best move ever.
  4. Nando85
    43
    6
    Aug 9, 2017
    What you delete?
  5. JohnnyC
    173
    65
    Feb 17, 2009
    The variable veined turbo that came with the truck. Nothing but trouble. Old style turbo now. Runs great, 7 plus mpg every day.
  6. Nando85
    43
    6
    Aug 9, 2017
    From the looks of my pics the oil the turbo is gone right? I didn't see any smoke
  7. JohnnyC
    173
    65
    Feb 17, 2009
    Mine was smoking like it was on fire. I would have run the engine dry if I didn’t shut it down. In no time it pumped out and burned 5 gallons of oil.
  8. Nando85
    43
    6
    Aug 9, 2017
    06 freightliner century 14 liter Detroit 60 series... no smoke just the oil from turbo to cac ??? Anyone seen this before?
  9. Opus
    132,117
    Kinda looks like somebody did a poor job of putting on the filter and may have been over tightened to make a seal as a result.
    Nando85 Thanks this.
  10. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    if you got oil in your cac hose on turbo side. your turbo is shot. if the oil makes it to the intake side. your motor will run away. it will suck every drop of oil out of the engine
  11. truckdriver31
    6,998
    8,363
    Sep 18, 2013
