Hey Uniden and President Electronics!!!
Discussion in 'CB Radio Forum' started by russbrill, Aug 26, 2019.
  1. russbrill
    russbrill Medium Load Member
    325
    226
    Nov 10, 2017
    Here's an e-mail I sent to both manufactures of two-way radios.. Tell me or them what you think, would drivers be interested in a more modern radio service for the consumer?
    Dear Uniden,
    In my previous e-mails I suggested 38 MHz as a viable part of the radio spectrum for a new radio service. However, after additional research I have concluded that the 49 MHz portion of the spectrum may be much better.
    Midland USA is pushing GMRS Radios to off road enthusiast. However, GMRS is on UHF and is only Line-of-Sight without the aid of a Repeater.
    Citizen's Band needs a 21st Century re-boot, and yes, I have an idea.
    I was thinking about areas like Paradise California and how a new local/regional radio service may be a benefit. I know about FRS (short range), GMRS (poor in hilly terrain), and 27 MHz CB Radio (Local comms are Ground Wave, that = short range), none of these services work well in hilly or mountainous terrain.
    I concluded that a new public radio service on the VHF Low Band combined with an existing VHF High band service would serve communities like Paradise much better than the ones listed above. Check out my band plan below... (The 49 MHz frequencies will require FCC approval)
    U.S. 49 MHz VHF-Lo *MURS Band Plan
    TX/RX Mode of Operation FM (10 Watts rms)
    Channel / Frequency / Bandwidth / Recommended Use
    1A. 49.6750 (20.00 kHz) Interstate Highway Channel – Long Range
    2A. 49.6950 (20.00 kHz) Off Road Vehicle (4WD) channel --- Long Range
    3A. 49.7150 (20.00 kHz) Long Range Talk Around Channel
    4A. 49.7350 (20.00 kHz) Long Range Talk Around Channel
    5A. 49.7550 (20.00 kHz) Long Range Talk Around Channel
    6A. 49.7750 (20.00 kHz) Long Range Talk Around Channel
    7A. 49.7950 (20.00 kHz) Long Range Talk Around Channel
    8A. 49.8150 (20.00 kHz) Long Range Talk Around Channel
    9A. 49.8400 (20.00 kHz) Emergency / Travel Assistance ONLY
    10A. 49.8650 (20.00 kHz) Long Range Talk Around Channel
    11A. 49.8950 (20.00 kHz) Long Range Talk Around Channel
    12A. 49.9150 (20.00 kHz) Long Range Talk Around Channel
    13A. 49.9350 (20.00 kHz) Long Range Talk Around Channel
    14A. 49.9550 (20.00 kHz) Long Range Talk Around Channel
    15A. 49.9750 (20.00 kHz) Long Range Talk Around Channel
    *Multi Use Radio Service (see Title 47, Chapter I, Subchapter D, Part 95 Subpart J)
    U.S. 150 MHz VHF-Hi *MURS Band Plan
    TX/RX Mode of Operation FM (2 Watts rms)
    1B. 151.820 MHz (11.25 kHz) Short Range Talk Around Channel
    2B. 151.880 MHz (11.25 kHz) Short Range Talk Around Channel
    3B. 151.940 MHz (11.25 kHz) Truck / Cargo Terminals --- Calling Channel
    4B. 154.570 MHz (20.00 kHz) Off Road Vehicle (4WD) channel --- Short Range
    5B. 154.600 MHz (20.00 kHz) Interstate Highway Channel – Short Range
    Intothesunset Thanks this.
  3. russbrill
    325
    226
    Nov 10, 2017
    NO Comments???
    Wow.....
  4. Road*Runner
    Road*Runner Light Load Member
    94
    259
    Jun 14, 2015
    Speaking of that, what are the radios that the trucks on the ice road use? They appear to be VHF. I would be interested in something like that. A lot of deer hunters around here use marine band radios to talk to each other. ( not legal of course, but no one is stopping them) VHF would be nice. No static and good range.
  5. AModelCat
    164,773
    In Canada CB is dead. Its all pretty much VHF now.
  6. russbrill
    325
    226
    Nov 10, 2017
    Are they using Commercial VHF frequencies? Or has Canada made some changes and opened up some VHF spectrum to their citizens for personal use?
    Intothesunset and marmonman Thank this.
  7. Ridgeline
    22,726
    123,431
    You do know that the FCC and other government agencies are in control of this ... well actually the frequency allocation os governed by the ITU and another group.
  8. russbrill
    325
    226
    Nov 10, 2017
    To address your comment: The FCC would need to work with the NTIA, and the ITU already has the 49 MHz spectrum listed as "Land Mobile"...
  9. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Why are you whining to a manufacturer about federal regs? It wasn't their idea...
  10. russbrill
    325
    226
    Nov 10, 2017
    ??? …. I don't get your comment...
  11. skellr
    8,735
    12,187
    Jul 17, 2011
    Nobody needs a licence for 49mhz? or even above 30? Once you get into 30 it's CW for a bit... it wasn't the idea of any radio manufacturer.... It was something "Charlie" wanted to do.
    Or are you saying those frequency's are "free and open".
