high beam
Discussion in 'Questions From New Drivers' started by Omega7777, Oct 10, 2018.
  1. Omega7777
    Omega7777 Medium Load Member
    392
    414
    May 21, 2018
    what is going on with everyone at night with their high beams on at all time !? if you are a blind bat, dont drive at night ;(
    is this pretty normal to deal with in your trucking career ? very annoying. absolutely 0 consideration
  3. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    If it's an older truck he probably has a headlight out. Maybe the driver forgot to switch them off, or maybe he's an ### hole... depends.
  4. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    It might not be the high beams but non adjusted lights but them new lights they are coming out with keep getting brighter, get some good shooting glasses that have that yellow lenses, it cuts the glare and as we age we have less tolerance for bright lights it seems. Get one of them fancy eye tests that have all those lights shooting and they looks into your eyes to see if everything is still connected correct.
    Lepton1 Thanks this.
  5. Omega7777
    392
    414
    May 21, 2018
    it is crazy to realize how many of them leave them on and im sure they know it ;) and no it is not because it is LEDs, could tell the difference
  6. Omega7777
    392
    414
    May 21, 2018
    do have a pair of those and definitely could tell when it is on high beam and most will turn them off but some are ########. but maybe you are right about the new LEDs, most pickup trucks, they must all put in the brightest ones
  7. 8V149 Detroit
    8V149 Detroit Bobtail Member
    38
    24
    Mar 20, 2017
    It may not be their high beams had that happen the other night going done a narrow road, one of those new short buses. I thought the person had their high beams on (their normal beam was as bright as my high beam) so I flashed mine to try to tell them to turn theirs off, then they flashed their high beam then I got even more blinded
    bottomdumpin and Lepton1 Thank this.
  8. Omega7777
    392
    414
    May 21, 2018
    lol is not fun for me to guess while driving. on the positive note, it keeps me awake for being annoyed
  9. wis bang
    wis bang Road Train Member
    3,454
    4,098
    Jan 12, 2011
    Levittown, PA
    Wife's car has projector headlights.
    I've noticed that there is a 'cut off' line when the lights hit the neighbor's fence; the upper portion of the beam is flat like there is a shield keeping the upper part hidden.
    Now on the silky smooth highways of our dreams this wouldn't be an issue.
    Real bumpy roads cause the 'hot spot' of the lights to bounce up into the eyes of everyone and they flash their brights until I flash mine back and now we all can't see right.....
  10. WesternPlains
    6,366
    57,263
    Sep 1, 2017
    Rapid City, SD
    Some put the brighter led’s in. They’re all over the place. Not sure if even legal?
    My Toyota has three settings for headlights. Low low. Bright low. Then high beams. Holy cow high really lights up everything.
    I fear that some people have similar. Are running against traffic with the low Brights. At the least is rude.
  11. Moose1958
    Moose1958 Road Train Member
    15,290
    33,957
    Dec 17, 2010
    Williesburg, Virignia
    Driving at night caused me horrible problems. The flashing high beams just as I was looking at my California mirror and many other things NOT just the bright headlights. I have a problem with my retinas that cause me headaches. I worked with my ophthalmologist (medical doctor) and we worked out a great solution. I wore what was heavily tinted nighttime driving glasses and an eye drop like this one. Not a perfect solution, but it did help a lot.
