High crank case pressure
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RBT, Jan 5, 2015.
  1. RBT
    RBT Bobtail Member
    8
    I bought an 08 kenworth c-15 cat 2 weeks ago. It keeps putting high crank case pressure code and derating engine. I have changed blowby filter, crank case pressure sensor, and still having problems. No visible blowby. Have had back to dealership twice, nothing shows up on computer.
    HELP!!
  3. PurplePete
    PurplePete Light Load Member
    131
    24
    Nov 15, 2011
    Tyler, Mn
    I have a c15 to but do not know where that sensor is located. If the wiring harness is damaged the c15 sensors are designed to break instead of the ecm.
    Also remove the oil fill cap while the engine is running and check for blowby there as well.
