high flow t600 muffler
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dieseldan2005, Jun 28, 2013.
  1. dieseldan2005
    dieseldan2005 Light Load Member
    185
    17
    Feb 6, 2009
    North Branch, MN
    Does anyone know if there is a donaldson replacement flow through muffler for a 2007 t600 with a c15 in it? I have the under bunk single muffler. I know donaldson had stack mufflers for 379's and such, but is there a direct fit one for that big catalytic muffler on the t6?
  3. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    if it's the same thing as the w9. like yours it was one muffler under the cab.
    design wise i didn't see any difference on the insides between the high flow and stock mufflers. only difference was shorter length.
    saw no difference in fuel mileage. but that truck ran mostly westerner mountains.
  4. dieseldan2005
    185
    17
    Feb 6, 2009
    North Branch, MN
    Its different than a w9. I don't have duals. I have weed burner exhaust and the muffler is an inlet at one end and an outlet at the other. Looks just like a stack muff turned horizontal. Only diff is this one is mega big because its the catalyst one. The w9 has the funky u shape i think.
  5. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Donaldson # M-100463 is their high flow muffler, the same one for the Pete's just a year less warranty when mounted horizontal, you can use the same brackets just change to 10" bands. I got my bands from my local KW dealer, TruckPro and Ryder have the best price on the muffler.
  6. dieseldan2005
    185
    17
    Feb 6, 2009
    North Branch, MN
    Perfect! Thanks alot. Did you notice any performance gains at all?
  7. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    I have twin stacks on my Star and I replaced them with the 463 Donaldsons. They sound great (to me!!) and it seemed to rev easier but I didn't really see any gain in mpg. The power did seem to improve a bit (might be all in my head) with the old Catalytic muffs, it has to be an improvement.
    Bill
  8. rollin coal
    rollin coal Road Train Member
    13,654
    28,093
    Mar 29, 2008
    TN
    100463 are longer than stock, the flex from the muffler exit into the upward turning elbow is eliminated, but that's not a problem. Been running with two underneath my t600 for about 3 years now no problems, great sounding muffler deep tone. Will probably be much louder with a single 5" stack.
    Sent from my droid using Tapatalk 2
  9. dieseldan2005
    185
    17
    Feb 6, 2009
    North Branch, MN
    Guys, i bought all the parts to install my new muffler this weekend and i have a few problems. One the brackets are too long for the new donaldson since its not as big around. How did you guys raise up your brackets or support the new muff? Also what part numbers were the new 10" straps? My KW dealer couldn't find anything for me. I told them basically give me the stuff for a t600 with a cummins because i don't think they have the catalytic muffler. If you guys could even post a pic of how you raised up the muffler that would be great!
  10. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    140
    Sep 2, 2008
    MIDLAND, NC
    I put 463's on alot of the under exhaust trucks. The catalytic muffler is larger in diameter. Just take floor jack under existing brackets and jack up... If you watch your placement and alignment you can bend them up just perfect to cradle the 463's RW
  11. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    that's what I did then shortened the stainless steel bands that hold it in place.
