High idle on a Cascadia Smartshift
Discussion in 'Experienced Truckers' Advice' started by Boy Howdey, Aug 16, 2015.
  1. Boy Howdey
    Boy Howdey Medium Load Member
    May 22, 2013
    632
    Thanks Received:
    1,370
    A month ago I bought a 2010 Cascadia with DD15 10 spd Smartshift. Been a really good truck so far. But i can't get the high idle to set. It idles around 850rpms.
    Anyone know how to set the high idle? Or is there something wrong with it?
  2. uncleal13
    uncleal13 Road Train Member
    Apr 9, 2009
    3,797
    Thanks Received:
    6,295
    Humboldt, Sk
    Hmm, you know too turn on the cruise and hit resume, then toggle up or down to adjust the revs.
    Unless it's been locked out.
  3. Boy Howdey
    May 22, 2013
    632
    Thanks Received:
    1,370
    Yes I've tried that.
  4. HardlyWorkingNeverHome
    HardlyWorkingNeverHome Heavy Load Member
    Mar 18, 2008
    709
    Thanks Received:
    316
    Hamden,CT
    ECM probably set so you can't do that. Probably need to hook up the computer to it and check the settings.
  5. Mr.X
    Mr.X Heavy Load Member
    Oct 31, 2013
    737
    Thanks Received:
    596
    Spokane, WA
    Have you tried setting the idle up with the trailer brake locked and tractor brake released? Cant really think of anything else.
  6. Boy Howdey
    May 22, 2013
    632
    Thanks Received:
    1,370
    Yes i have. Wondering if it's an ECM issue.
  7. HardlyWorkingNeverHome
    Mar 18, 2008
    709
    Thanks Received:
    316
    Hamden,CT
    Company truck with opti idle or anti idle it would be off. They use the ambient air sensor to determine wether it can idle or not. Most companies are setting about 40 degrees to 68 degrees as a window the truck won't extended idle. If it can idle at the lower setting for long periods, it won't hurt anything more than it would at 1000 rpm.
    Mr.X Thanks this.
  8. Boy Howdey
    May 22, 2013
    632
    Thanks Received:
    1,370
    This truck came from USA Truck. Should I call their maintenance department and ask them?
    I bought this truck from Lone Mountain Leasing.
    I though idling under 1000 was bad for the truck and builds up carbon?
    Mr.X Thanks this.
  9. Mr.X
    Oct 31, 2013
    737
    Thanks Received:
    596
    Spokane, WA
    Yeah the work around for that one is drive nights during the summer, and days during the winter. I drove for an outfit that had it set at 40f and 80f.
  10. Mr.X
    Oct 31, 2013
    737
    Thanks Received:
    596
    Spokane, WA
    Thats a good idea! Don't know about carbon build up but we always bumped the idle up on the pre-emisions engines because it was smoother and supposed to be better for the engine and turbo got ample oil supply.
    Boy Howdey Thanks this.
