High pitch whining noise when accelerating
Discussion in 'Volvo Forum' started by Vanjasolo, Feb 4, 2025.
  1. Vanjasolo
    Vanjasolo Bobtail Member
    2023 volvo vnl860 i just bought is making a high pitched noise when gas pedal is pressed all the way and the boost is ~25psi. It doesn't start whinig right away though and doesn't whine when i'm bobtail. I think it might be one of the belts but i'm worried it might be the turbo. Did anyone have similiar issues or know what this is?
  3. Oxbow
    Oxbow Road Train Member
    13,669
    141,737
    Nov 24, 2015
    I know nothing of Volvos, but that could be normal turbo noise, or a leak in your charge air cooling system.
  4. Vanjasolo
    I drove a 2016 volvo last year and it didn't make that noise, I didn't think of the cooling system, I'll give that a check for leaks or cracks
  5. sirjeff
    sirjeff Medium Load Member
    When that truck is cold and you fire it up, take advantage of the boost it makes when it warms up. Spray down all rubber/silicone boots, and joints. I'll bet it's a tiny crack in the o ring between the charge air pipe and the air to air on the turbo side. I have changed out probably 10 of those over the years on my vulva.
    Big Road Skateboard and Oxbow Thank this.
  6. Big Road Skateboard
    7,104
    40,327
    May 2, 2021
    To verify, @Oxbow is referring to boost hoses , clamps, cac, intake, etc, leaking turbo boost pressure. Not cooling system as in radiator.
    OLDSKOOLERnWV and Oxbow Thank this.
  7. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    Boost leak. Get a spray bottle with water and a little dish soap. Spray everything and look for bubbles. Also, look over the boost system for black residue. That'll point you to a crack/leak as well.
    Oxbow Thanks this.
  8. OLDSKOOLERnWV
    19,146
    289,566
    These men are on the right track…
    Most likely this is where you will find your mystery noise. If it’s doing it only when you reach 25 psi boost it’s no belt squealing…..
    Oxbow Thanks this.
