High winds - I-80 vs I-70?
Discussion in 'Experienced Truckers' Advice' started by PermanentTourist, Mar 4, 2018.
  1. PermanentTourist
    PermanentTourist Heavy Load Member
    749
    881
    Nov 9, 2016
    48 states + Canada
    Hi guys.
    Tomorrow we have to take a light 4000 lbs load from Denver to Seattle. This is a no-fail team load, and I am an independent owner op, so calling the dispatch and wimping out like a company driver is not an option. For tomorrow they are predicting 50mph+ wind gusts on 80 in Rawlins WY, but "only" 40mph+ on 70 up in the Rockies.
    What should we do? Is I-70 a better option? Or do the mountains just make the wind gusts worse?
    IluvCATS Thanks this.
  3. bzinger
    bzinger Road Train Member
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    No fail ? What's that ? Only fail load is livestock and then ya find a sale barn and off load em .
    This is ground transportation not air freight .
  4. PermanentTourist
    749
    881
    Nov 9, 2016
    48 states + Canada
    And if you don't unload the cows and they all die, it's still not a fail, right? You won't go to jail or anything. Only the broker won't give you any more loads and you will lose your business. No big deal.
    bzinger and rabbiporkchop Thank this.
  5. Moosetek13
    Moosetek13 Road Train Member
    14,985
    19,037
    Nov 1, 2010
    Burnsville, MN
    Wow, SuperTrucker 101 - no wimping out like company drivers.
    Tell me, Super, if you roll the load due to high winds - will that be a fail?
    More of a failure than waiting it out and getting the load there safely a day later?
  6. 06driver
    06driver Road Train Member
    2,436
    3,434
    May 28, 2017
    There is no such load as no fail. And pulling the brakes because of weather is called safe operation.
    Now 50 mph cross winds and an empty trailer make for
    But hey at least he was not a wimp right:rolleyes:
    70 does cause some unexpected cross winds, but so can Wyoming. My advice is to run 287 up to 80 and play it by ear. 10mph is not that big of a difference, and your more likely to hit pop up weather on 70 IMHO.
    spyder7723, Dave_in_AZ and Moosetek13 Thank this.
  7. FullMetalJacket
    FullMetalJacket Road Train Member
    3,308
    5,550
    Oct 16, 2013
    Vagrant
    Got to stay up on weather forcasts & what is happening.
    Also, have I-25 up to 90 as option, so that gives you 3 options now.
    Similar distances, but 80/84 shortest by a bit. 70 & 90 close to same.
    70 hits much, much higher elevation & accompanied unexpected conditions that go along with those elevations.
    Crap shoot except for watching weather, but I would say 70 most likely to cause most unexpected issues.
  8. drver60021
    drver60021 Light Load Member
    59
    21
    Mar 5, 2013
  9. Espressolane
    18,680
    117,076
    Just a guess here, your not used to running the intermountain west.
  10. PermanentTourist
    749
    881
    Nov 9, 2016
    48 states + Canada
    Not exactly new to it, just usually run pretty heavy, and always avoid I-70 through Colorado when possible. Now considering it because of the light load.
    bzinger Thanks this.
  11. Radman
    Radman Road Train Member
    2,087
    2,559
    Apr 18, 2011
    I-70. Wouldn’t mess with Wyoming that light. I’ve ran Den to SLC for 6+ winters now for 5 years I did it 5-6 days a week 365. If you want to for sure make it i70 is the best option.
    Lepton1, DTP and PermanentTourist Thank this.
