hill climbing fast vs slow
Discussion in 'Experienced Truckers' Advice' started by shatteredsquare, Jul 11, 2021.
  1. shatteredsquare
    shatteredsquare Road Train Member
    1,407
    1,841
    May 23, 2014
    middle dirt
    full throttle at 45 mph with hazards on burns the same amount of fuel (or more, because not assisted by any momentum) as full throttle at 70 mph. if you hit the hill at 75 you can get to the top at 60 lickety split. if you hit the hill at 65 or lower, you're at 45 halfway up and takes twice as long to get over. given full throttle in low gear burns the same (or more!) fuel as full throttle in top gear, where climbing slow takes twice as long...climbing slow burns more fuel in hill county than hauling az and throwing it over the top :bounce:
    slow.rider and Bean Jr. Thank this.
  3. Autocarjockey
    Autocarjockey Bobtail Member
    27
    59
    Jun 28, 2021
    One method might get you a ticket and one won't lol
  4. LoboSolo
    LoboSolo Heavy Load Member
    737
    4,267
    Jun 21, 2013
    Highway 20
    I think it depends on what you've got under that hood, and how big the hill is.
  5. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    Really more, at least per mile. Let's say at full throttle you burn a gallon every 6 minutes. At 75 mph, you would have burned 10 gallons in an hour, 7.5 mpg. At 45 mph, you still would have burned 10 gallons, but only having gone 45 miles, your mpg is 4.5.
    All of course academic as there is no 45 mile long climb, as far as I know. But still....
  6. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    I'm out West, so very commonly do grades. Also, my normal gross is around 78k. In those conditions, not sure it matters much about fuel consumption. It's gonna take lots of fuel to get up those grades.
  7. slow.rider
    slow.rider Road Train Member
    2,005
    4,741
    Apr 4, 2017
    NYC
    Yeah when the mountains is 5 miles high then you're gonna test the truck no matter what. But you can still get a running start which should help a little bit. In Appalachia they're steeper but not so tall, so the running start is often enough to get you over the hump without a downshift. I kick up my speed in Appalachia on the theory that it'll deliver better mpg, or at least less wear on the truck.
    Bean Jr. Thanks this.
  8. Bean Jr.
    5,573
    9,929
    Mar 30, 2014
    Exactly! About 1/2 mile into a long pull, you're in the gear you're going to be in, no matter how good a run you get at it.
  9. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    You burn more fuel as your taking longer at full throttle to climb the hill.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    If the hill is steep enough and long enough you’ll crest it at the same speed even if you start at zero.
  11. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Gotta find the right gear and sweet spot rpm....Gunning it and keepin it higher rpm all the way to the top dont make it better or any real faster..
    If it climbs at a steady pace in say 10th at 1300 and your pyro aint maxed out with boost maxed out you will do just fine..Actually you will save a few pennys here and there and at yrs end,it equals dollas in your pocket..
