HMD TRUCKING INC
Discussion in 'Discuss Your Favorite Trucking Company Here' started by OTRWife43, Jan 23, 2026.
  1. OTRWife43
    OTRWife43 Bobtail Member
    4
    Jan 23, 2026
    Started with the company about 9 days ago. The I’ve been in trucking for about 17years. From the start of placing the application in on Tenstreet to the flight, hotel stay and orientation…the process was amazing. Coming from Western Express which HORRIBLE…this was a major upgrade.
    The cpm is very fair, the process from hr to benefits was also welcoming. They are huge on communication which is big difference for me. The only hangup I can say right now is the maintenance side. My ABS light came on and the crew gave me some out of this world directions…cut truck on and off 15 times, squeeze brakes and a whole slew of crazy stuff. Outside of that company start off is going very well.
    Will update or answer any question that comes from here.
  3. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,232
    Sep 27, 2015
    ABS light on the truck or on the trailer? That could be as simple as a dirty wheel speed sensor, a wheel speed sensor that is unplugged, a wheel speed sensor with a frayed wire or casing that is exposing wire to metal causing a short. I think they might have been trying to tell you how to read the codes from the ABS light, if it is on the trailer. You can turn the key on for a few seconds, off, and back on again and see the ABS light flash on the trailer. Count the number of times it flashes. If it flashes the same number one time, it should be that there is only "code", so 5 flashes three times would mean the trouble code is "5" for that respective system, I do believe.
    OTRWife43 Thanks this.
  4. Lonesome
    Lonesome Mr. Sarcasm
    11,718
    24,466
    Dec 15, 2007
    Northern Indiana
    Good luck!
  5. buckmanmike
    buckmanmike Medium Load Member
    324
    424
    Jan 20, 2010
    in the country, georgia
    Why were you at Western Express with 17 years of experience? Good luck with your new job.
    Hawkeye72 Thanks this.
