Hole in DPF housing causing problems?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Paulgee83, May 17, 2019.
  1. Paulgee83
    Paulgee83 Bobtail Member
    10
    This is my 1st post here so I hope I am doing this right. I got the "scr performance low, repair needed 5mph limit at next vehicle stop". Codes we're 4094 fmi 18 and 5246 fmi 16. Took it into the shop and they drove it while connected to computer and said it was throwing out waaaay high nox value 300 ppm at idle 750+ when climbing with empty trailer. They found my egr valve to be bad. I paid and drove it 17 miles and same codes came on. After 2 days of diagnostics they came to the conclusion I needed injectors, cups, dpf cleaned and doc serviced. Paid and drove 300 miles same #### lights and codes now they are saying I have a hole in the bottom of my dpf filter housing and that is the reason it is throwing high nox and not doing a regen. 2013 Mack cxu613 mp7 engine. Does this sound like the problem to anybody? I am currently 11k in and don't want to spend another 5k if this sounds like bs
  3. Paulgee83
    10
    This is my 1st post here so I hope I am doing this right. I got the "scr performance low, repair needed 5mph limit at next vehicle stop". Codes we're 4094 fmi 18 and 5246 fmi 16. Took it into the shop and they drove it while connected to computer and said it was throwing out waaaay high nox value 300 ppm at idle and 750+ when pulling empty. They found my egr valve to be bad. I paid and drove it 17 miles and same codes came on. After 2 days of diagnostics they came to the conclusion I needed injectors, cups, dpf cleaned and doc serviced. Paid and drove 300 miles same #### lights and codes now they are saying I have a hole in the bottom of my dpf filter housing and that is the reason it is throwing high nox and not doing a regen therefore throwing the scr code. 2013 Mack cxu613 mp7 engine. Does this sound like the problem to anybody? I am currently 11k in and don't want to spend another 5k if this sounds like bs
    Reason for edit: A bit more info
  4. FlyingA
    FlyingA Bobtail Member
    46
    23
    Jun 3, 2018
    Sacramento, Ca
    It is possible. Why did they not catch it the first go around? Part of a DPF inspection is to check for any exhaust leaks as they will cause sustem to burn too cool.
  5. Paulgee83
    10
    The only reason I could see that they did not catch it is because I do see some insulation through the hole so maybe they only looked at it when it was opened from the top to send my filter to get cleaned and the only way u can see this hole is from the bottom. Not trying to make excuses for them as it is just poor workmanship either way.
  6. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    I’m not familiar with a Mack, but when they cleaned your DPF’s and serviced the DOC they should have found the hole. It is one of the standard checks before cleaning them.
    Next, if your truck had a Detroit and it threw a SCR efficiency Low code, I would have changed the Nox Sensors before doing anything else. Together they usually less than $500.
    Like I said I don’t know Mack, But I know Freightliners and if they where changing that stuff first for a SCR code....... My guess is they are too dumb to know what’s going on or worse yet, they do and they are just checking to see how deep your pockets WERE!!!
    But then again, I don’t know Mack.
    mhyn and BoxCarKidd Thank this.
  7. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Mack MP7=Volvo D13
    I am not a tech.
  8. Paulgee83
    10
    Nox sensors were changed in march. They pobably ran around 50 tests testing everything emissions related. I originally got a code and check engine light in March for the nox sensors which is why I changed them. This time I got the lightning bolt and the message but no check engine light
  9. Paulgee83
    10
    I texted the original tech about what the new shop found and asked what he thought and this was his techs response
  10. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    when injectors overfuel and egr valve malfunctions more soot goes to DPFs. During regen more heat comes out from DPFs. It causes SCR overheating/toasting . If temp value goes more than 1400F the SCR will throw low nox conversion codes . Sometimes this code will start popping up after 1 or 2 months
  11. Newto Trucking
    Newto Trucking Medium Load Member
    359
    225
    Dec 26, 2013
    NE Illinois
    Usually if the dpf outlet temperature reaches 950F during regen D13 would go in cool down state and stop fuel dosing and wait till the temperature drops and then start fueling again
