Holland Simplex 5th wheel play
Discussion in 'Freightliner Forum' started by 2hot2handle, Oct 28, 2019.
  1. 2hot2handle
    2hot2handle Light Load Member
    67
    34
    Aug 25, 2015
    I have play in my 5th wheel when you take a pry bar and go to either side and pry up. I also can see movement front to back on the rails.
    I assume the front to back movement is the slots it's in are worn but I cant get it to release to move it to another spot to confirm.
    I really don't like this 5th wheel setup but Freightliner told me to convert to a jost or fontaine the whole assembly needs to be changed out. If I don't slam this thing into the king pin the release handle doesn't fully retract and it doesn't lock completely. I'm tired of slamming my truck into trailers.
    For now I'm thinking just a rebuild of the pins and bushings to remove the side to side play and if the springs and jaws need done I'll do that as well.
    Does anyone know if Holland makes a better setup that is compatible with the same rails and release setup that the Simplex uses? I don't want to spend money twice. Thanks
  3. 062
    062 Road Train Member
    6,330
    33,970
    Oct 20, 2013
    You might want to contact jost directly with the model and serial number of what you have now.
    It’s been six years, but I had a fld and put a jost on with no changes. Took maybe 15mins.
  4. 2hot2handle
    67
    34
    Aug 25, 2015
    Thank you
    062 Thanks this.
  5. Rideandrepair
    17,562
    56,900
    Aug 8, 2015
    A standard holland should swap right onto your rails, I’m guessing. But you said your pins are bad, so you’d need those also, My thinking on that is that the rails are all the same. The Holland’s are very good simple design.New only around $850 at FleetPride. For plate only.
  6. Derailed
    Derailed Road Train Member
    2,384
    2,657
    Dec 10, 2008
    Upstate NY
    I know my 01 freightliner originally came with a Simplex and at some point was swapped over to an FW35 which is a great fifth wheel in my opinion. I think the slider is original to the truck. I just put an Atro urethane bushing/pin kit in. It was around $90.
