HOS driving violation
Discussion in 'Questions From New Drivers' started by nredfor88, Apr 3, 2020.
  1. nredfor88
    nredfor88 Road Train Member
    1,801
    6,100
    Sep 26, 2019
    USA
    I just got my first violation recorded on the Qualcomm. How much would a fine for something like this cost?
    I drive to the consignee. 2 minutes remains for drive time. Plenty of on duty time. Very large facility. Ran out of driving time going for door. Stopped changed to on duty - yard move. Got to 6 mph, went into violation. Stopped put it on PC, and docked my truck.
  3. kemosabi49
    10,977
    47,915
    Jan 13, 2013
    SW Arkansas
    On yard move speed should not be restricted to 5mph. Something wasn't right there.
    jammer910Z, Dave1837 and roshea Thank this.
  4. nredfor88
    1,801
    6,100
    Sep 26, 2019
    USA
    i used it the other day and I’m sure I was well above 5. I think the difference today is that I had zero time remaining to drive. The other day there was time remaining. Could that be it?
    How about potent fine cost? Hundreds? Thousands?
  5. snowlauncher
    snowlauncher Road Train Member
    1,307
    2,826
    Mar 28, 2014
    Southeastern ID
    1st of all, you would only be penalized by the DOT if they should happen to audit your logbook during an inspection. Depending on the amount of time that has passed since the violation, they may not even catch it.
    Second, you should be able to go in and comment for that change of duty status, that it was a yard move on private property. If it was only a very brief violation, it could be considered an honest and reasonable mistake, and probably a one time thing.
    Unless you get a DOT cop that has a hard on to cite you, it will probably be OK.
    Just be aware that it could happen again, and if you end up with several violations like this, it could get you into trouble.
  6. rachi
    rachi Road Train Member
    4,246
    5,231
    Feb 25, 2010
    SoCal
    Like snowlauncher said, your only busted by dot if they pull you in at the scale house and find it, or less likely later on in a company audit. You will need to call your saftey department and clarify that violation with them.
    tscottme Thanks this.
  7. Moose1958
    Moose1958 Road Train Member
    15,292
    33,960
    Dec 17, 2010
    Williesburg, Virignia
    FMCSA safety auditors are happy when they see violations have been "corrected" and they actually look for these corrections during audits. Don't be scared of safety. Let them know ASAP and they will tell you what to do next. Learn from it now and try to not repeat.
    tscottme and alds Thank this.
  8. nredfor88
    1,801
    6,100
    Sep 26, 2019
    USA
    Thanks for the advice. I’ve already notified my dm for further instructions.
  9. Valuable Asset
    Valuable Asset Light Load Member
    98
    293
    Feb 28, 2020
    Don't worry about it.
  10. nredfor88
    1,801
    6,100
    Sep 26, 2019
    USA
    lol, yep. My perfect record was bruised. I graduated today!
  11. Linte_Loco
    Linte_Loco Road Train Member
    1,618
    6,485
    Apr 24, 2011
    LA (lower Alabama)
    If that’s the worst thing that happened, it was a good day :)
    tscottme, snowlauncher and nredfor88 Thank this.
