HOS Infinity
Discussion in 'Experienced Truckers' Advice' started by AriGab, Dec 13, 2024.
  1. AriGab
    AriGab Light Load Member
    62
    27
    Feb 3, 2023
    Hey everyone, just curious what the maximum number of hours you can work per day and not need to restart? If my calculations are correct and I understand HOS correctly, if you use the 60/7 rule as long as you stayed below 8.5 hours every day that would be 59.5 hours in 7 days. Is this correct or am I way off? Thank you in advance.
  3. buzzarddriver
    3,854
    11,700
    Feb 1, 2011
    Dallas, TX
    You are correct.
    tscottme Thanks this.
  4. tscottme
    tscottme Road Train Member
    There is NO LIMIT to number of hours you can WORK in a day. Did you mean Work (On-Duty, NOT Driving ODND ?) FMCSA allows you to WORK 24/7/365/100 years. You would just need a minimum of 10 hours Off-Duty/Sleeper before you could drive legally.
    The limits are on DRIVING before you need some sort of rest/SLEEPER.
    If your question means ODND & DRIVING then your formula will allow you to drive every day forever. In trucking it is very important to understand the word "work" at every other job means doing something for the job. In trucking work means non-driving jobs related. The HOS add driving AND WORK together when calculating the 14 Hour Clock & the 60 or 70 Hour Clock.
    The FMCSA doesn't use a 24 Hour clock. They use 11 Hour Drive Clock, 10 Hour Off-Duty/SLEEPER Clock, and a 60 or 70 Hour in 7 or 8 day clock.
    Kyle G. Thanks this.
  5. AriGab
    62
    27
    Feb 3, 2023
    Yes I was referring to driving time. I heard about a guy that does a run every single day and at first I thought you always had to have a day off after 8. Then I thought about the hour scenario and wondered if that's how he was doing it legally.
  6. Moosetek13
    Moosetek13 Road Train Member
    15,004
    19,067
    Nov 1, 2010
    Burnsville, MN
    If you want to run on recap hours so you never have to do a 34, that is the way to do it.
    But that 8.5 hours includes both on duty and drive time combined, because those are the hours that count against your 60 or 70 hour limit.
    And those are averaged hours per day. If you only use 5 hours one day you could do 12 hours another day in that time period and still be OK.
    tscottme and AriGab Thank this.
  7. pavrom
    pavrom Road Train Member
    3,224
    7,465
    Apr 29, 2012
    NE illinois
    ...he meant legally:)
    JolliRoger, Kyle G., tscottme and 2 others Thank this.
  8. buzzarddriver
    3,854
    11,700
    Feb 1, 2011
    Dallas, TX
    But, if you finesse that one day off each weekend, you would have your 34 hr reset and start each week with a fresh 60.
    JolliRoger, tscottme and AriGab Thank this.
  9. AriGab
    62
    27
    Feb 3, 2023
    Ya I was doing that lol. If I did the run between 5 and 7 am Saturday I could do it again on Sunday after 3 to 5 pm correct?
  10. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    If you ran based on 70/8, you would be able to change up your hours slightly
    AriGab and tscottme Thank this.
  11. tscottme
    The carrier usually decides if you run 60 hour in 7 days or 70 hours in 8 days.
    AriGab Thanks this.
