HOS Question
Discussion in 'Questions From New Drivers' started by RayBlaszak, Jan 31, 2019.
  1. RayBlaszak
    RayBlaszak Light Load Member
    208
    146
    Aug 20, 2015
    Is there anything that we do on duty that doesnt come out of your 70 hour clock?
  3. RDBG
    RDBG Medium Load Member
    309
    692
    Jun 23, 2016
    Nope.
    flood Thanks this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Plus, if you are asking that basic of a question, I highly suggest you going and getting the green book and read it from front to back.
    At the very least read Part 395 located at eCFR — Code of Federal Regulations
  5. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Yup, go off duty. IE your driving back to your home with out a load. You can post yourself as off duty and it no longer applies to drive time.
  6. RayBlaszak
    208
    146
    Aug 20, 2015
    My follow up question because I cant find it is what is the rule regarding checking in at a customer? I log it exactly how it's done meaning if it takes me 2 minutes my logbook shows two minutes. I'm constantly battling my company with this and would like to show them that the regs do or dont specify a required time meaning you must log 15 minutes to check in and and 15 to check out which is what they say
  7. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    It sounds like you're using paper logs if company says minimum 15 minutes. That is the only advantage to electronic logs, e-logs go by actual time, paper only allows 15 minute blocks. However, think this through: pull into shipper/receiver log goes from DRIVING to ON DUTY, set brakes,walk in check in, walk out open doors set axles move and park in dock....can you really do all this in 2 minutes? Probably not! This could be why company says 15 minute minimum. Basically the same time once loaded or delivered coming out of the dock.
  8. MACK E-6
    50,097
    239,039
    Technically no, but people will only know what you tell them.
    otherhalftw Thanks this.
  9. MACK E-6
    50,097
    239,039
    Why can’t check-in to check out just be part of the same line 4 block?
  10. RayBlaszak
    208
    146
    Aug 20, 2015
    I use Elogs. I go to a lot of places where you literally walk in they sign your paperwork say dock 2 and wave and say have a nice day. If I go to Walmart and it takes 15 minutes I log 15 minutes. I called safety and they said what I said to do it as I do it.
  11. RayBlaszak
    208
    146
    Aug 20, 2015
    I put check in as my first logged event and log the check out separate as it occurs. So my log looks something like this.
    Check in 10 minutes
    Sleeper berth customer loading unloading
    Check out 3 minutes
    Vehicle and safety check 2 minutes
    Than I go about my day
