HOS Violations who will hire me???
Discussion in 'Experienced Truckers' Advice' started by flatbedd777, May 1, 2025.
  1. flatbedd777
    flatbedd777 Bobtail Member
    I have 2 HOS violations in the last 2 years. Is it possible to still get hired by a good company?
  3. Moosetek13
    Moosetek13 Road Train Member
    14,986
    19,040
    Nov 1, 2010
    Burnsville, MN
    Wow. That is worse then failing a drug test or a 20 over speeding ticket. Maybe worse than a rear ender.
    Did you notice the sarcasm?
    So what were the 2 HOS violations?
  4. tscottme
    tscottme Road Train Member
    Like @Moosetek13 said, it depends on what the actual violation is. What is listed on your PSP?
    It also depends on how you define "good company".
  5. flatbedd777
    I applied for a job recently and they didn’t go forward after the background check. Both violations where excee
    The company I applied for didn’t go forward after the background check. Due to two violations of exceeding 14 hour clock and failing to provide shipping numbers on E-log
  6. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    Form and function violations should not be in the BASIC of HOS.
  7. D.Tibbitt
    157,230
    Wow.. that sucks.. where are u located. U do flatbed work?
  8. tscottme
    Any company can have as high a standard for hiring a driver as they want. For example a company COULD decide they are not hiring drivers who have ever been late for work at any job since time was created. It may mean, practically speaking, they can't find any driver to move their freight.
    The point I am making is that ONE company or multiple companies may decide to not hire you but that doesn't mean all companies will also not hire you. The companies don't join online registries where they declare the details of who they will and will not hire. Keep applying to other trucking companies. Understand that the freight volume is still low, so the need for more drivers is not like it was 2-5 years ago. If I was in your shoes, I would focus on the employers of drivers you already know in real life. Apply at their employers. Apply at companies you see in the area where you already are/were working. Apply at companies you may know SOMETHING about already, if you would like to work there. Companies are not required to give a reason why they don't hire. ANYTHING on a PSP report hurts you to some degree from getting hired. You can get a copy of your PSP report immediately for $10 at the FMCSA link I'll put in this reply. There may be a way to get a free copy of that same report, but I don't know. Don't give up, and don't get any more violations they hurt you more than anyone else.
    Pre-Employment Screening Program
  9. bryan21384
    bryan21384 Road Train Member
    15,743
    34,315
    Sep 18, 2009
    Memphis, TN
    Yes it is. I worked for a cheap, somewhat outlaw owner years ago. Got pinged for inspections left and right. My CSA score got kind of high. Magnum turned me down because of it. Climate Express didn't care about the CSA score and took me. Both companies have pretty good reputations. It all depends on a company's requirements, or whatever their insurance carrier requires of that company. Post your location, perhaps you can get some good leads.
  10. Cabover_Pete
    Cabover_Pete Bobtail Member
    Yes. I bet that most of us have had more than 2 HOS violations in the last two years.
  11. BlackjackCo
    BlackjackCo Light Load Member
    155
    644
    Mar 29, 2024
    Are you located anywhere (or willing to relocate) to areas running agriculture loads. Not all but many are running ag exemption and need drivers actually will to work at least 14 hrs if not more (especially during harvest times).... I always run non-stop anyway but first of the year harvest started yesterday so I'm not only running my usual loads .... I just started running local mill run loads to keep the feed at the dairy because the normal local drivers are hauling chop and not the local feed they normally do.
    It's Fri night and I've already put in 16 hrs and 629 miles today. And I'm under the hood loading first of 9 loads (each is 5-6 hr round trip and about 180 miles) that my boss and I between the 2 of us have to get loaded and delivered in next 36-48 hrs
    Needless to say, my bet is an agriculture trucking company is likely less as concerned about HOS violations and more concerned that you have a work ethic. Not all drivers have to do the extreme my boss and I do (we have 4 drivers who refuse to help with these extra loads). But it's available and because I will always help, I get paid very very well.
