hey guys i got a glider. d60 12.7 colunbia.
today i felt my blower go weak. my ac started getting real weak. i tested my heat. didnt get much of any heat. its 85 here outside. so i should of been sweating heavy. i took a pic pf my ac lines. i noticed its ice. any idea why both heat n ac went weak and why blower got low low
hot cold blower help. d60 12.7 glider
Discussion in 'Freightliner Forum' started by 4noReason, Aug 15, 2020.
If after turning off the ac for 20-30min it returns to normal, then the evaporator is freezing up.
Rideandrepair Thanks this. -
will that cause my heat to not work tho
do u mean the heater core underneath the truck.
truck didnt start today. all power died.
Did you get it fixed? What was the problem, alternator?
Your AC compressor is running constant causing your AC to freeze up
Your AC is running constantly causing your lines to freeze up.
