Hot markets.
Discussion in 'Ask An Owner Operator' started by Edjahman, Feb 8, 2021.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    Hello.
    I know this may be a dumb question but I'm still learning things.
    I've been looking into current markets and it seems to me that you would go to the ones with the high load vs truck ratio.
    Is there a reason that any of you personally don't do that? If you don't like a particular market then do you stick it out in your preferred market?
    I understand it's about going where the money is at that point in time.
    Thank you
    Take care
    D.Tibbitt and Rideandrepair Thank this.
  3. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    Usually it’s a one way deal. Chicago has a lot of loads going East. Good rates. Not many coming back, bad rates. Other lanes have more of an even ratio both ways. Average rates. Finding the best combination for overall average net, has always been my goal. You can just try to chase good rates, but best to know what to expect on next load. 3.00 one way, and 1.50 back, avg. 2.25 all miles. Etc. Sometimes a triangle ( 3 trips) works better, for instance. With the bad rate on the shortest trip back. Or a short day trip, with a high rate, before loading a longer trip, to pump up average. Or bouncing back on 2 trips instead of one. Whatever works best for you. Time, fuel, wear and tear on you and equipment, all plays a part. I’m certainly not an expert. Just doing the best I can. Always looking for a better net result.
    Opendeckin, PPLC, Final Drive and 12 others Thank this.
  4. 86scotty
    86scotty Road Train Member
    4,699
    12,897
    Aug 27, 2017
    Appalachia
    Well said, R&R, that pretty much sums up the way I do it.
    Final Drive, TallJoe, xsetra and 4 others Thank this.
  5. Edjahman
    648
    444
    Apr 2, 2013
    Thank you!
    Rideandrepair Thanks this.
  6. Edjahman
    648
    444
    Apr 2, 2013
    Thank you!
  7. Edjahman
    648
    444
    Apr 2, 2013
    I'd like to maybe rephrase my question a little bit after much thought.
    It's seems obvious to me that some drivers or a lot of drivers will go and work in different markets depending on what's hot and what's not.
    Maybe some other drivers will stick it out in a so-so market because they really dislike certain other markets.
    I've been looking at the truck to load ratios in markets that I don't particularly like and I'm wondering to myself if I should just suck it up and go to these other markets even though I don't particularly like them.
    Obviously it's the smartest thing to do financially, it seems.
    I hope that this explains it better.
    Thank you
  8. Edjahman
    648
    444
    Apr 2, 2013
    Would you purposely go to a market that you don't like because it's hot and the truck to load ratios are really high?
    I was thinking about relocating to other markets that I really don't like because it seems obvious that financially it's a good decision whether I like the area or not.
    Thank you
  9. Edjahman
    648
    444
    Apr 2, 2013
    I have also been reading about triangulation strategies to maximize revenue and I've actually been practicing that myself so I understand that part.
    Midwest Trucker and Rideandrepair Thank this.
  10. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    Im not saying it’s the best strategy, but personally I try to run areas I like. I also tend to stick with what I’m familiar with. This weeks a perfect example of why. I took a different Load to a different area. Rate was good. Snow storm came in and missed appointment. Lost a day, and now in a bad spot for a weekend run. I tend to stay with what’s consistent, instead of chasing the dollar. Seems to average out the same overall. Same reason I don’t pull a reefer. Not interested in following the seasonal markets. Right now, I should take a load to Minnesota, I know I’ll get a good load out of there. Would be the smart thing to do. But I don’t want to go to Minnesota. So I won’t. But it’s my choice. Other tempting Loads are Arizona and Florida. Mainly for the weather. Not taking those because I’ll probably take a loss getting out of either. Still looking, I’ll probably find something better tomorrow. If not an average load to keep the Truck moving will be available. I’ll take my chances, and wait till the last minute. Need to focus on where I’ll be Monday. Bottom line is might as well do what makes myself happy, and not stress about any of it. Plans change, can’t avoid it. Just have to go with it. I mostly play it by ear. No real strategy. No sense in counting on anything, since is always changing. Being able to change plans seems more important to me. Not letting things out of my control get me upset.
    PPLC, Dino soar, JMon and 1 other person Thank this.
  11. Edjahman
    648
    444
    Apr 2, 2013
    Thank you. I really appreciate your replies.
    I like the markets that I run in and I was doing good until January and it's been a huge struggle. I was just considering changing markets completely but I'm not completely losing my shirt so maybe I can stay put until spring and see.
    Take care
