Hotshot need help
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Fatbedder94, May 16, 2019.
  1. Fatbedder94
    Fatbedder94 Bobtail Member
    4
    Jan 25, 2019
    Hey guys I have a 2500 dodge ram diesel 2018. Looking at getting a 16 gn 8k axle trailer. Is that within the guidelines of not having a non cdl hotshot. I have a cdl I drive semis. Just dont want to anymore. Everybody talks about gvw gvwr gvwr and all that. The gvwr I found only in for the ram is 10000 lbs and the trailer gvwr is listed at 17500. So that means I'll be over the 26k. So will I only be able to get a 14 gn because it's under the 26k. Bcs gvwr on the 14gn is 15700
  3. Grumppy
    3,236
    11,428
    Dec 11, 2010
    West Monroe, La
    No. You can get a 40 ft as long as its under 16,000. Length has nothing to do with it.
    stuckinthemud Thanks this.
  4. flatbedcarrier
    flatbedcarrier Medium Load Member
    667
    827
    Jun 8, 2005
    Southern California
    Will you be keeping your class A license?
    If you’re letting the cdl A license go? Many states, like mine have a rule that says the trailer you’re pulling must have a gvw of less than 10,001 lbs if you don’t have a class A drivers license. Check with your state before buying a trailer just to be sure you’re not tossing your money away. And with many trailer mfgr’s, they’ll de rate the trailer for you but only when buying it. They usually won’t change it after it’s been purchased.
  5. 24kHotshot
    24kHotshot Heavy Load Member
    801
    874
    Feb 19, 2019
    New York
    The 2500 has a very small payload. Assuming you have the crew cab 4x4 long bed, you have a 2200 lb payload. A fully loaded 14k lb trailer might overload the trucks rear axle. 15-25% of the trailer weight transfers to the truck I'm told.
  6. Lite bug
    Lite bug Road Train Member
    1,413
    35,688
    May 3, 2014
    Columbus Ohio
  7. Lite bug
    1,413
    35,688
    May 3, 2014
    Columbus Ohio
    Are you trying to stay under 26?
  8. Fatbedder94
    4
    Jan 25, 2019
    Yes. But keeping my cdl.
    Lite bug Thanks this.
  9. Lite bug
    1,413
    35,688
    May 3, 2014
    Columbus Ohio
    You can use your 2500 Ram with a 14K Trailer and stay under 26. As Flatbed said be sure to check with your home state to verify. There is a couple of hoops you don’t have to go thru by staying under 26. Try to get a longer trailer 34 to 36 to maximize the type of freight opportunities.
  10. Lite bug
    1,413
    35,688
    May 3, 2014
    Columbus Ohio
  11. 24kHotshot
    801
    874
    Feb 19, 2019
    New York
    The biggest 20 ft trailer is a 20 ft trailer. CDL has nothing to do with the trailers length. It's a gross weight issue. Your truck and trailer need to be 26000 lb or less to not be cdl. A few states don't allow more than a 10,000 lb rated trailer without a cdl no matter the size of the truck.
