Hotspot vs. tether to phone?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by steve-in-kville, Dec 25, 2025.
  1. steve-in-kville
    steve-in-kville Light Load Member
    64
    113
    Feb 14, 2025
    I've been using my phone to stream. I have a good plan, unlimited data, so far, so good. I am looking to add a Roku screen or tablet to my truck.
    Should I bounce for a dedicated hotspot for the truck? Or tether off my phone?
    tscottme Thanks this.
  3. BrothaTrucka513
    BrothaTrucka513 Medium Load Member
    516
    988
    Aug 30, 2020
    If I could tether the Wi-Fi off of this ELD tablet, I'd be a happy camper.
  4. keebler13579
    keebler13579 Heavy Load Member
    992
    1,985
    Nov 16, 2012
    Look at your plan. Depending on your plan you may be limited on hotspot usage from your phone. I have unlimited data but only 30 gig hotspot usage. There are plans with unlimited hot spot but they cost more
    tscottme and nextgentrucker Thank this.
  5. tscottme
    tscottme Road Train Member
    I agree with @keebler13579 . Look at your plan. Most plans have a hotspot data limit even if the phone data limit is unlimited. I've seen someone suggest that if you run a VPN then the carrier cannot tell if you are using the date on the phone or over the hotspot. I don't know if that's true. Other than that, I would try running your phone as a hotspot, stream the most demanding thing you anticipate watching/using (4k movie/gaming/etc) and if my phone got hot while doing that "worst-case scenario" and I had the money for a physical hotspot, I'd get the hotspot. If it doesn't get hot, skip the hotspot. I would anticipate that if you use the phone as a hotspot and also recharge it at the same time you will heat up your phone, especially if the phone screen is active for all of that.
    BTW my phone carrier has a screaming deal over next 9 days for unlimited data, talk, text, unlimited hotspot for $16.30 per month if paid in a lump sum of $195 for 12 months. I've been using them for 4-6 months and love them. There are no additional fees, taxes. You pay the listed amount. The deal I described limits you to the ATT network. You would need to check the details for their Unlimited Premium and also remember to enter the discount code of HALFOFF
    usmobile.com
  6. Arctic_fox
    4,509
    25,491
    Sep 16, 2016
    They can tell. 99% of phones use X amount of data and send X type of imput signals. If you really want to use your phone to steam id recomend a good unlimited plan then get a TV thats compatible to cast to. Same effect without any of the sketchy.
  7. tscottme
    thanks
  8. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    I use a Verizon homefi. $45 a month true unlimited data at 4g-5g.
  9. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    I took a minute to read your question, and after reading all the replies, I looked at your question again. While all the replies are right, did your question actually get answered? Here is my ---
    ---! Assuming your plan has enough hotspot data, the decision to use wifi over tether, in my opinion, would be based on what your hardware will allow and the speeds. I have used both wifi hotspot and tethering and found the speeds to be about the same. What makes this such a difficult decision is that phones are so different. I have an old Android phone where the wifi was weak, and the better speed was to tether. On my iPhone, there is no real difference.
  10. MidWest_MacDaddy
    11,409
    19,509
    Feb 21, 2015
    South Carolina
    Multiple options.
    Depends on usage.
    If it’s a Tablet, most carriers will sell you an add on package to your phone plan. Unlimited data (on tablet) and might be able to hotspot that data as will, if needed. Then bounce the other devices off either.
    I had a hotspot with a small high speed package but then unlimited data at slower speeds. Worked well in combo with both iPhone and iPad mini each with its own data package. Ran my gps and other low speed items off it.
    Recently replaced the hotspot with StarLink. They have a nice unlimited BUT slow speed package for only $5/mo. Good enough for YouTube, voice calls, email, social media.
    You didn’t mention gaming, but at that point you just bump up the StarLink to the unlimited high speed package for low latency.
    so many combinations… if just streaming on a phone and tablet and nothing else, consider an add on data package for your tablet. (If it’s has cellular options.)
    As mentioned above, many do seem to have good luck setting up their trucks with “home cellular service” data packages. Good option if they don’t notice your “home” wandering around the Country and shut it off… but I have no first hand experience with that myself.
    good luck.
