How cold will it start
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Richter, Jan 2, 2014.
  1. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I just bought and installed a bunk heater so i don't need to run the truck for warmth. kept me warm the last few 15 degree nights. I have great batts with 4000 Cold Cranking Amps. They have cranked fine at 15 degrees. I run fully synthetic oil 5w40 (not partial synthetic, recommended for use in motors that need 15w40 mineral oil) So, do i need to run the motor tonight or will she start fine at 8 degrees tomorrow morn? My Bottom line likes just running the heater which is much much cheaper, but i don't want to get stuck either. In the past I always idled bellow 15, but im wondering if that is necessary. Oh yea, Its a Detroit S60 (EGR) in a 06 Columbia.
    Thanks
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    you just wont know until you get to the point it just doesn't start
    good batteries and good compression it should be fine
    if it has been rebuilt already no reason for it to not start
    a million miles on an 06 without a rebuild might be dicey
    Richter Thanks this.
  4. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    740k w/o a rebuild lol
  5. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,486
    Oct 18, 2009
    Waynesburg, Pa
    If your parked where you can get help I'd take my chances. If your out in the middle of nowhere I'd idle.
  6. truckman29801
    truckman29801 Medium Load Member
    469
    109
    Mar 10, 2013
    SC
    Keep a can of Either. when its cold 5 degrees F with Non Synthetic 15w-40 I know my truck well enough that the first 15 or 20 cranks are going to be the strongest, so i usually spray a 3 second shot of either in the breather and then turn it over until it starts. But i hardly ever have to do that.
  7. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    If you've got a place to plug it in, you could. I'd run it, myself. No-start service calls suck. I only shut the truck off below 15 at my house, where I can park out of the wind and plug it in.
  8. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    i have shut my truck off while i was with friends in ND. was gone for day and a half. it started at -1. it didnt like it but it did start. i have just over 345k on it
  9. DL550CAT
    1,427
    1,486
    Oct 18, 2009
    Waynesburg, Pa
  10. damutt
    1,126
    370
    May 6, 2013
    it did,, just sounded really sick. after a few min it sounded nomral. personally i would never shut the truck off below 10F
  11. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    Why not run it for an hour, shut it down for 3 then run it another hour and so on?
    Don't forget to pack your jumper cables. Then you can watch all the nice drivers look at you holding your cables up in the air while they zoom past you in the truckstop!
