How did I get away with this?
Discussion in 'Experienced Truckers' Advice' started by Midnightrider909, Aug 8, 2018.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    I have been driving for three years and was under the impression that if you are over 34,000 pounds on the tandems they are going to hand you a ticket. We picked up a load in Arkansas. I was asleep at the time and my wife figured the weights were good since we have loaded there before many times and never had a problem. It was only 37,000 pounds and our truck can haul 46,000. We get pulled in at the point of entry for Oklahoma and they make us weigh and then after what seemed an eternity stopped on the scale they let us go. We proceeded without getting weighed through OK and KS and then get pulled in to weigh in CO and WY. In Wyoming my wife had to stop the truck and bring in her paperwork but they never mentioned anything about her weight. I took over driving in Wyoming and then get pulled in the Utah scale. By this time I’m thinking WTF because we hardly ever get pulled into a scale with our pre-pass and then I slowly roll over the scale and notice that the drives have 24,000 pounds and the tandems have 34,760. Most scales don’t tell you what your axles weigh as you roll over them so this was quite a surprise for me. What was even more of a surprise was the “exit to interstate” sign flashed on and I counted my lucky stars and kept on rolling. My question is did we use up all of our luck for the year on this one trip or does this routinely happen where you are a few hundred pounds over and they just let you go? This isn’t the first time I’ve been lucky with the DOT. I got called in for a level one once in California and air was hissing through the gladhands seal like crazy and the guy let me go with a passing score and told me just to change the seal before I motored on. Another time in Virginia I was 3000 pounds over on the drives and the guy just told me to adjust it and re-weigh and no ticket then either. Am I the luckiest trucker in the US?
    Truckermania Thanks this.
  3. Poonok
    Poonok Light Load Member
    178
    249
    Apr 25, 2018
    Il
    If they arnt being jerks i think they mostly care about gross. You werent over by a lot, but still could have been handed tickets. Some states have different weight limits above 34k on tandems as well but i dont know if the ones you went through were any of them.
    LoneCowboy and Tb0n3 Thank this.
  4. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    They didn't have a problem with the cut of your jib.
  5. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    Maybe they looked in the cab and could see that I was a clean-cut upstanding member of the American populace and therefore cut me some slack.
  6. win-some-loose-less
    win-some-loose-less Medium Load Member
    691
    997
    Apr 19, 2010
    Mount Vernon tx
    I haul bulk which means I’m always close on weight or a little over.. I’m happy at 500 over on tandems and will roll with under 1000 over.. just depends on the state and if they are being a-holes or not.. I don’t mess around in Virginia tho lol Oklahoma won’t say anything if you not atleast 1k over.. these are axel weights, over gross is a total diffrent story.
  7. jschapm2
    jschapm2 Bobtail Member
    10
    Nov 30, 2016
    Greensboro, NC
    And yet your avatar represents a domestic terror group.
  8. DSK333
    DSK333 Road Train Member
    2,413
    2,756
    Jan 27, 2018
    Pennsyltucky
    Maybe they were commie sympathizers too and were glad to see a comrade out on the roads. Stalin and Marx granted you safe passage from the Heavens.
  9. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    I thought it was just some pretty flags.
    Oldironfan Thanks this.
  10. rbrtwbstr
    rbrtwbstr Road Train Member
    3,402
    7,948
    Jul 11, 2012
    in the bush somewhere
    Don't dare try that in Maryland... They'll write a ticket just to see the reaction on your face
    rabbiporkchop and Oldironfan Thank this.
  11. Atlanta trucker
    Atlanta trucker Road Train Member
    1,608
    2,009
    Jan 25, 2017
    I haul up to 39,999.99 pounds on my tandems in Florida no troubles at all. Good idea is to look at that commercial road atlas. You would be amazed at the info you never knew , at least for me ...
