How do I adjust chassis height ?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Greggg, Feb 10, 2020.
  1. Greggg
    Greggg Light Load Member
    161
    35
    Jun 30, 2018
    Hey I’m wondering how do I adjust my leveling valve to lower the height of my chassis ?
    also I had the same issue a few weeks ago, and I’m guessing the leveling valve went too high again, can it be the leveling valve itself or one of the fittings ?
  3. AModelCat
    165,305
    If the height is in spec, leave the valve alone. You'll mess with the driveline angles and end up with vibrations and excessive u-joint wear.
    Isafarmboy, pushbroom and flood Thank this.
  4. Greggg
    161
    35
    Jun 30, 2018
    That was my issue last time it was too high had to lower the valve, now I’m starting to have the same isssue
  5. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
    What is the issue you are trying to fix? Ride height valves don't randomly change height. What type of truck and suspension?
  6. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    Are you eyeballing it or using a tape measure.
  7. Greggg
    161
    35
    Jun 30, 2018
    My truck made like weird grinding noises at higher speeds, took it to a mechanic he lowered the valve and it all stopped, seems like it’s starting again though
  8. Greggg
    161
    35
    Jun 30, 2018
    mechanic used a tape measurer
  9. Pete friessen
    Pete friessen Bobtail Member
    Feb 10, 2020
    What I have done before is if you think it's set to high then just drop a little air while driving not too much and see if it gets better if it does then you know for sure it's to high and if it gets worse then it's either set to low or some other issue possibly a u joint
    And as far as adjusting the height control valve it's just 2 bolts that need to be backed off a bit and then you turn the valve assembly to raise or lower the truck
    hope that helps
    Rideandrepair Thanks this.
  10. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If the bolts have not got louse and let the valve move, then you will need a new not rebuilt ride height valve.
  11. Rideandrepair
    17,580
    56,948
    Aug 8, 2015
    Sounds like it’s Not allowing air to dump properly, only airing up. You can disconnect the rod at end of arm, and check operation of valve. Pushing arm up, adds air, arm down, air should dump out. If not, valves bad. Look at the way arm mounts on valve. Usually 2 bolts. 1 on end of arm, another that’s slotted. Loosen both, adjust the arm position on the valve. The adjustment may be on the mounting bolts on valve itself, that is, arm is bolted stationary on valve, and valve itself has slots in it for adjustment. Play around with it, you’ll figure it out. Most importantly ofcourse is to get height set correct. I usually make a template, from cardboard, cut to the correct size, and use that as a “ spacer”. or guage. Easier than tape measure
