How do I close trailer door?
Discussion in 'Questions From New Drivers' started by bearsalad, Nov 20, 2016.
  1. bearsalad
    bearsalad Light Load Member
    104
    56
    Oct 18, 2016
    My trainer says I need to fogure it out myself but I vant. The door keeps getting stuck on something but I checked all alone the doorway and hinges and nothing is working. Now theres like a crowd of 10 people watching me and I just want to curl into the fetal position and cry.
    Xzay Thanks this.
  3. dptrucker
    dptrucker Road Train Member
    4,705
    3,243
    May 14, 2012
    adelanto,ca.
    Is truck and trailer inline? Sometimes if tractor is parked at an angle door wont close all the way.
    dog-c and roadranger550 Thank this.
  4. KillingTime
    KillingTime Road Train Member
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
  5. Jacoooooooo
    Jacoooooooo Heavy Load Member
    748
    1,054
    Oct 20, 2013
    Make sure the trailer axles are positioned on the even pavement. If they aren't, especially under load trailers (mostly older, tired ones) will slightly twist and hooks will be off the position to catch the latches. If it's on even, there may be an issue with the top not closing, than you need to push it, make sure it all goes where it should. For opening issues, if they tend to get stuck, open both at the same time.
  6. 51.50
    51.50 Heavy Load Member
    894
    1,943
    Jan 20, 2016
    Salem Oregon
    If the trailer is not level, the body will actually twist preventing the door from closing. Close the left door first. Have the door handle turned all the way to the right. Close the door enough to engage the latch. As you turn the handle to the left, the latch will pull the door into the locked position. Repeat for right side door. Hope that helps.
    Rusty Trawler and x1Heavy Thank this.
  7. bearsalad
    104
    56
    Oct 18, 2016
    Fogured it out. Left door needed to be shut first.
    Thanks for the help.
  8. 51.50
    894
    1,943
    Jan 20, 2016
    Salem Oregon
    Your trainer is a poor excuse.
    Grubby, Longarm, Bfr38 and 28 others Thank this.
  9. TurnpikeTourist
    TurnpikeTourist Bobtail Member
    43
    65
    Apr 12, 2015
    Long Island, NY
    Usually the box just twists a little, pull up 10-15 ft and see if it levels out. Otherwise just use a crowbar and a bigger hammer!
    x1Heavy and Kalin72 Thank this.
  10. Kalin72
    Kalin72 Light Load Member
    124
    65
    Apr 3, 2015
    And do not forget to use the magic words!!! In Bulgarian we use мама ти да...which is very close to FYM in English :) Works like a charm!
  11. VIDEODROME
    VIDEODROME Road Train Member
    1,487
    1,297
    Jun 7, 2007
    angola, in
    I've had some real pos trailer loading out of a wood mill with a very uneven yard and it would just refuse to latch all the time. Sometimes I'd get out on the industrial park road and pull over with my blinkers on and see if it would be less 'twisted'.
    TurnpikeTourist Thanks this.
