How do I get additinal power
Discussion in 'CB Radio Forum' started by 1989 Pete, May 14, 2009.
  1. 1989 Pete
    1989 Pete "Pine Tree Eater"
    I'm going to get a Connex Turbo soon what else can i purchase with this to be in the 500 -700 wattage range?
    Thanks?
  3. Lightninrod
    Lightninrod Light Load Member
    51
    Mar 29, 2009
    Warner Robins, GA
    Maybe an amp from your Connex source?
  4. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    I would stick with a Dual Final radio, something like the Connex 3300 or General Lee, and get a 4-pill Amp to go with it...Then you'll be able to swing in the 500 to 600w range easily...Or go with a 1x4 or 2x4 amp, and get in the 900 to 1000w range!
  5. 1989 Pete
    Thanks driva I'm new to the cb power thing!
  6. 1989 Pete
    Do you have a website where i can compare these things?
  7. FriedTater
    FriedTater Keeper of The Snakes
    2,202
    887
    Mar 25, 2009
    United State of Texas
    Technology has pretty well evened the Field on amps
    Any of these will be very close when the PEP shakes out.
    XForce
    FatBoy
    Davemade
    Worldwide
    Messanger
    Texas Star
    1989 Pete Thanks this.
  8. 1989 Pete
    Thanks now when running these amps do i need to hook up any other power source to run all of this or will the normal power setting be enough?
  9. FriedTater
    2,202
    887
    Mar 25, 2009
    All Amps should be hardwired directly to the batteries.
    150-250 use 8ga w/ 40amp fuse
    250-500 use 6 ga w/60 amp fuse
    Always use crimped or soldered connections,never use black tape.
  10. 1989 Pete
    thanks for all your help i'll definatley keep ya posted!
  11. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    If you are looking for Messenger amps talk to Stringbean379 in San Diego California. He knows Ray (the guy who builds them) personally.
