How do otr drivers cope with these situations?
Discussion in 'Questions From New Drivers' started by ad356, Oct 15, 2019.
  1. ad356
    ad356 Road Train Member
    2,138
    3,179
    Mar 13, 2017
    I was driving rt20a through warsaw NY. The road after rt19 was closed. Apparently some meat head was speeding down the hill and lost control. He crashed into an oncoming car. The result was a road closure.
    As a local driver.... These are my stomping grounds and I know the area. I took rt19, saltvale, Lagrange rd (this actually takes me past one of my farms), and rt246.
    As a local driver it took me until the light turned green to figure out how to reroute. I could see something like this being a real pain if you don't know the area. Blindly following the GPS while driving any cmv is a bad idea.
    So how do you OTR guys cope with this type of thing? There are no detour signs.
  3. Opus
    132,786
    Park until they clean it up. It's all you can do
  4. Espressolane
    18,747
    117,609
    If you have an area that is clear and can pull off the road, then that’s the first thing. Then get on google maps or similar and look at the area. If a reasonable work around is available, take that. If not. Sit it out and go when it clears up.
    cybill234, McCauley, Woodys and 4 others Thank this.
  5. HillbillyDeluxeTruck
    5,960
    30,500
    Mar 3, 2013
    San Antone
    I usually cuss whoever caused the detour, then try to check my map on my phone or tablet to see if there's a simple route around. If not, I'll pull over and take a few min to figure it out. I might even do a u-turn!
  6. rcelmo
    rcelmo Medium Load Member
    459
    1,986
    Mar 23, 2015
    Depends whether I am loaded or not. If I am empty I will risk running
    small back roads......loaded heavy not so much. Also depends where it is. If
    I am in flat country and the fields are dry I might try a gravel road.....just had
    lots of rain I will stay on bigger hard roads.
    Check the map and if no good options I will park it and wait. GPS combined
    with a little common-sense goes a long way. Tablet with google earth can be a life
    saver.
    Also depends on the road closure. Single car crash will likely be cleared fairly quick.....
    multi-car/multi-fatality, road will be closed for a while.
    Intothesunset Thanks this.
  7. ad356
    2,138
    3,179
    Mar 13, 2017
    Back roads can't bother me. Allot of my farms are on Back roads. Some are even on 10 ton roads but the milk must be picked up. Seems stupid that they would make a road with a farm on it a weight restriction.... But I have 2 that are like that.
    I avoid restricted roads when I can but if the farm is on that road no avoiding it
    Intothesunset, magoo68 and FlaSwampRat Thank this.
  8. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    In the situation you described I follow the milk tanker lol.. IF that don’t work I ask a local if possible or whoever closed the road
    Intothesunset, FlaSwampRat and tinytim Thank this.
  9. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    which is why i fully appreciated in my earlier years, running the highways, rather than state/county, back roads. you can always take an exit (almost always you are pushed off to an exit) and follow back to the highways.
    now, fast forward to my latter years, and running dedicated......many times i had to get off the main road due to an accident...NO GPS available......rand Mc Nally at times, was not any more of a help then sticking my finger out the window to feel which way the breeze was.
    no detour signs, no people, and no one on the cb radio......now what to do..????
    i'd take an exit, and by sense of direction, find a way back to the main road....not always at great success however..lol...but never caught in a tight spot, low overpass, etc....
  10. Jwhis
    Jwhis Heavy Load Member
    862
    1,356
    Jan 17, 2018
    Listen to the CB. Check the GPS. If there’s a cop nearby ask them.
    Intothesunset and starmac Thank this.
  11. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    Dig into that Rand McNally for bridge heights and length/weight restrictions on alternate route.
    I always check.. especially the bridge height section.
