How do you disable the speedometer on a paccar 2016?
Discussion in 'Ask An Owner Operator' started by scoobertdoo, Oct 23, 2022.
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    With the speed limiter coming, I figured I would ask now. I assume it's somehow worked into the abs system? When the truck went into limp mode on the test drive I tried unplugging the transmission speed sensor, but no luck, it still read the speed, and wouldn't go over 5mph.
    Any knowledge on this one? I'm not about to go 60mph unwillingly.
  3. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,383
    Jul 16, 2012
    Bentonville Arkansas
  4. wichris
    wichris Road Train Member
    4,529
    9,335
    Jan 17, 2011
    Go in the ECM and change the rear end ratio/tire RPM
  5. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    I'm curious if anyone has the latest version of Volvo Premium Tech Tool and knows if the ability to adjust the road speed is still in the software. I know there was talk of even dealers not being able to adjust the road speed last January after an update.
    I plugged my truck in and adjusted the road speed to maximum and haven't tried to use the software since it begged me to upgrade.
    Siinman Thanks this.
  6. Dino soar
    Dino soar Road Train Member
    4,817
    27,071
    Dec 8, 2017
    If you alter your truck to go faster than the speed and they catch you what kind of a ticket are they going to give you for that?
    Siinman and Bean Jr. Thank this.
  7. 062
    062 Road Train Member
    6,352
    34,035
    Oct 20, 2013
    @nasriza may know.
    If you change the gear or tire rpm. It’s going to show a lot more miles on the odometer. I don’t know what trucks have it, but some have a “drivers reward”. It will give you xx mph for X amount of time.
    The older trucks with two speed sensors will work fine with the gear/tire rpm.
    @Goodysnap
  8. Long FLD
    Long FLD Road Train Member
    13,017
    54,639
    Mar 4, 2015
    When all of this came back up a few months ago the FMCSA said it would be up to the carriers to make sure they were in compliance. I wonder how many times you can get caught before it becomes an insurance issue and affects your authority.
    Siinman, Oxbow and Dino soar Thank this.
  9. Ridgeline
    22,774
    124,521
    Ever think that the ELD you have in the truck will be required to check the speed of the truck?
    While it is a good thought, this isn't the 2005, they will unfortunetly enforce this because of the drivers from the revolving door of these CDL schools are too STUPID not to speed.
  10. kay_ray
    kay_ray Medium Load Member
    492
    1,236
    Jun 6, 2019
    Donot go to stealership for software update . You will be fine
    Siinman and Oxbow Thank this.
  11. roundhouse
    roundhouse Road Train Member
    3,213
    7,335
    Jul 11, 2018
    Or if you install taller tires it will show less miles , and a lower speed than what you’re actually running
    Aamcotrans Thanks this.
  12. REO6205
    REO6205 Road Train Member
    13,168
    60,501
    Feb 15, 2014
    California.
    They'll be looking to make some examples of the first ones caught. I think we all know what that means.
    bzinger and 48Packard Thank this.
